Results 1 to 12 of 12
Thread: How possible is a backfire?
    Dec 2018
    San Francisco
    ‘81 E21 320i
    Question How possible is a backfire?
    Think my '81 backfired today - but not sure.
    Is this common? Right after fueling it up to start without a working cold start.
    Apr 2014
    DFW TX USA
    1983 320I, 1986 325E
    Mine backfired all the time since the fuel distributor had issues. I wouldn't worry too much about it.
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool
    At Start up-Engine firing out of Timing,valves out of adjustment, Leak in the air intake, Clogged Air Filter--exhaust valve is slightly open and combustion takes place--too much fuel generally--when the car is running a misfire in a cylinder can be caused by fuel injector dripping + spraying instead of just spraying.
    Randy
    Corona California
    79 320/6 81320i 65malibu
    Just a reminder that back firing can blow off vac lines.
    Do not step on gas, open the throttle when you start it first time.
    Cold or warm?
    This is new did not do it here?
    Always FUN TO DRIVE - Build Thread & Tech info - 79 320/6 track car build thread -- Videos of track car -Adam in car Auto-x video - Start-up video - 4/2011 Adam's TOP BMW time San Diego BMWCCA - 4-5-15 Dyno break-in run new M20B25 - Exhaust Thread - Link
    Houston, Tx
    '78 320i
    First and only backfire I had was due to fuel delivery issues and it blew the boot right off. Scared me half to death and the boot went flying
    Nov 2007
    Cool
    Backfires are solvable, most of the time too much fuel
    Randy
    Dec 2018
    San Francisco
    ‘81 E21 320i
    I pumped gas on cold start on a cold evening. Hasn't happened since. All the rubber stayed in place and it still idles the same.
    Corona California
    Quote Originally Posted by mcgee View Post
    I pumped gas? not sure what you mean?
    pushing gas paddle only lets more air in.
    Dec 2018
    San Francisco
    ‘81 E21 320i
    Forgot it's not a diesel.
    Corona California
    What no black smoke screens? LOL
    monterey, ca.
    e21, e30 m3. e46 330ci
    pumping the gas is a outdated procedure requirement of carburetors, doing so sets the high idle throttle seat, closes the choke plate to reduce air intake and pumps additional fuel directly into the carb's throat.
    fuel injection, starting with the Kjet that our cars use, does not require nor should the gas pedal be pumped before or while starting the engine.
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
    14 f800gsa - red headed stepchild!
    Feb 2009
    District Nine
    sold 78 BMW 320i
    If the mix is too lean, it can pop out the exhaust too. And especially if valves are too tight as Randy mentioned.
    Tbd
  1. E36 M3 Rough Idle, Sputtering, Backfire. Possible DME issue. Help...
    By seized in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-07-2020, 05:37 PM
  2. Possible backfire, now wont run?
    By absentmathis in forum 1991 - 1999 (E36)
    Last Post: 01-25-2008, 01:45 PM
  3. Waaayy crazy idea, dunno if even possible.
    By Black Majik in forum 1991 - 1999 (E36)
    Last Post: 03-01-2001, 04:28 PM
  4. "POLL" of possible new Categories
    By Bob ///M3 in forum Forum Software Questions & Suggestions
    Last Post: 02-27-2001, 07:53 PM
  5. "Poll" of possible new categories!
    Last Post: 02-27-2001, 07:44 PM
