Results 1 to 7 of 7
Thread: Rear Suspension Rebuild
    Dec 2013
    San Antonio
    850,76 2002 &530,84 633
    I just dropped the rear suspension out of my car this evening. I think I have most of the bushings/ bearings but I just noticed that it appears to have a couple of 'ball joints' that I did not see when I ordered all of the bushings.
    There appears to be a ball joint on part 6 described as 'rod with rubber mounting' that is like a forward transverse rod. There is a bushing on one end and some sort of ball joint on the other?
    Part 19 is a vertical 'compression strut' with a bushing at the top and maybe a ball joint at the bottom.
    Has anyone had to replace the ball joints or rods besides the bushings that are pressed on? Thanks,
    Mar 2008
    montreal,Canada
    bmw 850
    6 is a rubber bushing,same with 20.
    Quote Originally Posted by JDP530 View Post
    Mar 2008
    montreal,Canada
    bmw 850
    i only changed the rubber bushing on 6 since the ball joint was still good, but had to change 19 because of play in the ball joint, dont know if 20 is still available separately.
    Dec 2013
    San Antonio
    Quote Originally Posted by razman850 View Post
    I was able to purchase bushings 6 and 20, but I thought the other ends of both links were just bolts. I didn't realize they are ball joints until I got suspension out of the car today. I guess if they are worn I will need to replace the arms.
    Mar 2008
    montreal,Canada
    bmw 850
    i already had complete spare arms but decided to change just bushing on 6, that one is easy to get to if ever the balljoint craps out, waist of money to throw away when you can still get few years out of it.
    Feb 2015
    Kuna, Idaho
    Too Many Cars (NOT!)
    I had to replace #2 on both sides. It was a HUGE PITA! Did it on the car. Never again!
    Mike Drives:
    BMW's
    E24 - 635CSiA - (1) 1985 (US)
    E24 - 635CSi - (1) 1985 (EC)
    E31 - 850iA - (1) 1991 (Black)
    E31 - 850iA - (1) 1991 (Calypso Red)
    E32 - 740iA - (1) 1994
    E32 - 750iA - (1) 1990 (Not an "L") (EC German National)
    E32 - 735iL - (2) 1990
    E32 - 750iL - (1) 1990
    E38 - 740iLA - (2) (1) 1997 & (1) 1998
    E38 - 750iLA - (1) 1998
    E38 - 740iA - (1) 2000 "Short Sport"
    E39 - 528iA - (2) - 2000 & (1) 1997
    Also:
    2015 Ram 3500 Dually, Cumins 6.7, Std.Cab. Long box 4x4 (To haul all this junk when necessary)
    2014 Dodge Dart Rallye (Daily Driver)
    2007 Mercedes Benz CL600 (Brabus SV12S)
    Mercedes Benz SL's - (1) (2002) & (1) 1999 500 - (1) 1999 600
    1967 Buick Riviera (2)
    Dec 2013
    San Antonio
    Can anyone provide part numbers for the grey plastic cable holders that attach to the upper wishbones on rear suspension that hold the ACs, EDC wires, etc? I think 61138355134 is the correct part for the cable clips on upper wishbones.
    I also broke one of the plastic junction boxes on back subframe and need a part number to replace one or both. Looks like this is the correct number for the black boxes, 61131392239. Thanks,
  1. Replies: 16
    Last Post: 11-23-2015, 10:36 AM
  2. Rear suspension rebuild
    By MCoupeVet in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-20-2011, 10:33 AM
  3. Replies: 17
    Last Post: 08-14-2010, 03:04 PM
  4. Rear suspension rebuild
    By God in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 05-07-2009, 01:58 PM
  5. Lincoln Tech-Session/group help.... Rear suspension rebuild.
    By Dark Helmet in forum Great Plains & Rocky Mountains - US
    Last Post: 09-24-2003, 02:00 AM
