Results 1 to 7 of 7
Thread: BMW E31 Automatic Transmission Issues. HELP!!!
    Nov 2018
    Brooklyn, NY
    BMW 850i
    Hello All
    Any thought why transmission goes into all proper gears, but the vehicle will not move.
    Nov 2018
    Brooklyn, NY
    BMW 850i
    Hello All
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Lift the car, then let someone shift the lever and you watch at the side of the gear if the lever moves or not. Maybe just the bolt lose http://www.realoem.com/bmw/enUS/show...diagId=25_0007
    That is step one to check. Report back
    Nov 2018
    Brooklyn, NY
    BMW 850i
    Ok will do. I will keep you posted. Thanks
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Step 2
    Check your Transmission Fluid Level
    Jan 2005
    Japan
    Step 3: even when the lever moves, the shift selector valve could be broken, so nothing happens inside the valve body although you believe you shift
    Have recently seen several of such problems, especially on 5HP18 and 5HP30, but also 4HP24
    5HP18; 5HP18A; HP19; HP19FL; 5HP19FLA; 5HP19HLA; HP24; 5HP24A;5HP30 ZF 1056 327 173 https://www.thectsc.com/products/sel...alve-84-3.html
    BMW VW Audi 5HP18 5HP19 5HP24 5HP30 ZF 1056 327 170
    https://photobucket.com/gallery/user...MDkzOQ==/?ref=
    They do break. But you can replace them without dropping the valve body. You only need to remove the section that holds the valve. But remember that there is also a section on top of the valve body which is held on by the same screws. It may well stay where it is but to be safe, just insert some longer screws and lower the section with the valve in it, make sure it is hooked up to the lever
    Jan 2005
    Japan
    and another case of a broken manual shift valve in a 5HP30: E34-540i-transmission-stucked-in-D https://www.bimmerforums.com/forum/s...n-stucked-in-D
  1. Automatic Transmission Issue - Help greatly Appriciated
    By SammyD173 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 07-25-2016, 06:25 PM
  2. Bmw E60 Automatic Transmission Failure, please help!!!
    By f1driver1982 in forum 2004-2010 (E60,E61)
    Last Post: 08-08-2013, 11:07 AM
  3. 99 bmw m3 automatic transmission help
    By boosted323is in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 07-18-2013, 10:42 PM
  4. 97 m3 automatic transmission issue!? please help.
    By mylesM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-11-2011, 05:48 PM
  5. E36 1997 M3 Automatic Transmission Issue (Help Please)
    By zguy2112 in forum 1992 - 1999 M3 (E36)
    Last Post: 10-04-2010, 09:00 PM
