Results 1 to 5 of 5
Thread: Internal Fuel Pump Repair
    Feb 2018
    Fort Worth, TX
    82 320i 18 Jeep Wrangler
    Question Internal Fuel Pump Repair
    Just pulled out the internal fuel pump hanger and saw that a piece
    had cracked. I’m pretty sure it’s a positive or ground connection.
    Anyways I was able to pinch it in place for a quick fix, I wanted to know if I’m able to solder it back together?
    Didn’t take a pic of the actual part so here’s one that I took from online that cost 130$ that I don’t want to spend.
    Thanks in advance!
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    should be repairable, I replaced some internal tank wires on my E32 with new wires and soldered them. Looks like that parts is bolted on, so make a wire with 2 ring terminals
    monterey, ca.
    e21, e30 m3. e46 330ci
    thats a bonding cable (ground) and you can repair it, even if it's just crimping.
    also it should be noted that the pump is not entirely necessary, but living in texas during august means you should probably keep it working.
    Tom D
    77 e21 - m42
    88 e30m3
    04 330 dinan3
    84 r1000rt
    02 r1150rs
    all of them gray
    14 f800gsa - red headed stepchild!
    Nov 2007
    Sacramento, California
    1980 BMW 320i E21 M10B18
    Cool
    A Weld would work,,I went with Airtex as the electric fuel pump motor is replaceable plus Airtex has lifetime warranty.
    https://www.bimmerforums.com/forum/s...l-Pump-Rebuild
    Randy
    Feb 2018
    Fort Worth, TX
    Thanks fellas! Looks like I have some new plans for Saturday.
    Slowly but surely getting this bad boy ready to make its return to the streets!
  1. Internal Fuel Pump Testing
    By trthrrt489 in forum Forced Induction
    Last Post: 11-29-2018, 04:10 PM
  2. Fuel Pump/Sensor/Gauge repair questions..Help!
    By ga325i in forum 1999 - 2006 (E46)
    Last Post: 03-03-2011, 09:31 AM
  3. 2001 745IL Fuel Pump Repair?
    By vociti in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-06-2008, 11:50 PM
  4. $650 Fuel Pump Repair?
    By adjmcloon in forum 1996 - 2003 (E39)
    Last Post: 04-18-2007, 03:40 PM
  5. Need opinions on fuel pump repair.
    By Opus in forum Texas
    Last Post: 10-06-2006, 04:33 PM
