Results 1 to 6 of 6
Thread: Replacing stock AUX fan
    May 2013
    Las Vegas, NV
    UFO
    I am ditching the OEM aux fan to fit the intercooler I have. I have a Derale 18217 17" dual speed motor 1800/2400 CFM.
    My question is if I can connect the three fan wires to the corresponding AUX fan wiring to power this. Has anyone tried this before? I'm not sure on the stock AUX fan amp draw but I would assume they are similar? If not, just up the fuse? I would like the fan switched from the 80/88 sensor just like the OEM setup.
    CURRENT: LimeRockParkEdition E92 M3 - BSM/Silverstone E70 X5M - AW/Dove E36 M3
    PAST: Techno/Dove E36 M3 - Techno/Dove E36 M3 - LSB/Black E46 M3
    Vancouver, B.C., Canada
    '97 M3
    Fuse ratings are there to protect the wiring, itís generally not a good idea to put in a bigger fuse to stop the fuse from popping.
    May 2013
    Las Vegas, NV
    UFO
    Fuse ratings are there to protect the wiring, it’s generally not a good idea to put in a bigger fuse to stop the fuse from popping.
    Fuse slot #41 for the aux fan is a 30A fuse and the derale instructions shows 30A fuse for the fan. Do you think tapping the fan into the OEM wires and not running a relay would work?
    '97 M3
    It should be fine
    Sep 2008
    NJ
    96 M3, 97 M3
    This is what I did for my track car setup w/ a spal fan. I chose the power wire from the low speed relay. Forgot what color it was.
    Vancouver, BC Ca
    1993 325is
    I connected both the low speed and high speed wire together at the fan and it works perfectly fine. Runs like OEM.
  1. Best pusher fan to replace stock aux fan
    By silverbullet21 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 04-11-2012, 03:37 AM
  2. which Spal to order when replacing stock aux fan?
    By BMWFanatic in forum Forced Induction
    Last Post: 02-27-2011, 09:05 PM
  3. anyone replace the aux fan motor?
    By hc1001 in forum 1991 - 1999 (E36)
    Last Post: 02-20-2006, 02:22 PM
  4. how much does it cost to replace my aux fan low speed sensor
    By 328 is man in forum 1991 - 1999 (E36)
    Last Post: 08-29-2005, 05:47 PM
  5. Good Aftermarket Fan to replace blown Aux Fan
    By RRdawho? in forum 1992 - 1999 M3 (E36)
    Last Post: 05-18-2005, 04:16 PM
