RM European Auto Parts
Results 1 to 9 of 9
Thread: Tires
    Jan 2016
    Ca
    2001 525it
    Tires
    I know I will get some crap for this idea but here it goes, my wagon has the factory low suspension, the ride on the freeway is crap if the freeway is smooth then the ride is good. My tires are 235/45r17, I was at work looking at tire catalogs, because I work in the automotive industry and found that I can get a 235/50r17 tire the over all diameter difference is .95 inches. I don't care about the effect on the speedometer accuracy. Accelleration from a stop would be effected a little. A taller side wall will soften the ride a bit. It looks like i would have clearance and I don't really care about how the car would look when parked. I can think of any other effects it would have, it's a 525it and I just really cruise in it. Thoughts.
    Peoria, AZ
    03 zhp, 97 e36m3, 04 zhp
    I'd make sure that it is in fact the tires you have that are contributing to a harsh ride and not something else. e39 sport package is a very balanced ride if everything else is proper. We had a wagon for a short time that had bad subframe bushings and it felt terrible on potholes because of that.
    You don't have run flat tires installed, don't you?
    Jan 2016
    Ca
    2001 525it
    No runflats but my rear subframe bushings have leaked you can feel the subframe jiggles a little.
    NW suburban Chicago
    hiss by my window
    Quote Originally Posted by jclausen View Post
    Not a lot of difference in sidewall dimensions but I think you'll fine more comfort oriented choices in 50 series. You'll be raising your final drive ~4% which will probably drop highway cruise revs 100 rpm or so.
    Want a comfy ride? Get some 16" rolling stock.
    Jul 2013
    Casablanca, Morocco
    2001 e46 323i
    Quote Originally Posted by Mless5 View Post
    I second that. Bad bushings and dampers made my car drive like crap. Replaced them and the ride became much smoother with the same (225/45/17) tires...
    "If you have integrity, nothing else matters. If you don't have integrity, nothing else matters." Alan K. Simpson.
    5spd E46 "3XX": 328i engine, 330i Intake and exhaust, CAI, 323i diff.
    Michigan
    2005 325Xi
    +1 ... 235/50 16s would keep roughly the same rolling diameter, AND cush up the ride.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    +2
    Go with the 16" and you will feel the difference, as it has more sidewall to absorb the rough road. IIRC the stock on that car is a 225/55 R-16 for the summer and 205/60 R-16 for winter.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    16's ftw!
    Sep 2011
    Milton, WV
    2002 BMW 530i Sport
    Truth is that crap 50 series tires could actually feel worse. It depends entirely on the tire. I suggest you sort out your suspension first, repair/replace what needs repaired/replaced, then consider tires.
  1. Feedback on RE 730 tires.
    By JackH in forum 1991 - 1999 (E36)
    Last Post: 05-25-2004, 06:54 PM
  2. FS: 17-inch Axis Rims and Michelin Tires
    By V Shah in forum BMW Parts For Sale
    Last Post: 02-28-2001, 04:20 PM
  3. Good MA tire shops?
    By Scott Yu in forum 1992 - 1999 M3 (E36)
    Last Post: 02-28-2001, 01:45 PM
  4. "POLL" Wheels & Tires" Category
    By Bob ///M3 in forum Forum Software Questions & Suggestions
    Last Post: 02-27-2001, 08:06 PM
  5. FS: 17-inch Axis Rims and Michelin Tires
    Last Post: 02-27-2001, 07:27 PM
