Results 1 to 10 of 10
Thread: FS: E36 swapped S54 GTS3/4 race build
    Dec 2015
    westchester
    2011 E92 m3
    This is a feeler for my project. List is extensive. Selling because I just don't have the time to finish it and looking to buy property.
    Car starts right up! ..it runs, sounds great and all it needs at this point is to paint the interior and cage, install harnesses, window net. Front and Rear Aero should be installed...all up to the new owner.
    B
    uilt for NASA GTS3/4 THIS IS NOT A STREET CAR SO DONT ASK IF IT CAN BE CONVERTED BACK.
    Its a 98 coupe and been building it the last 6 months but priorities have changed.
    -Swapped an S54 with 100k miles on it. Previous owner installed new Rod bearings with ARP hardware. Has an euro oem exhaust on it with Scorpion muffler.
    -Authentic PTG Carbon Fiber Doors with OEM door handles installed and functional (6.5lbs) Each door.
    -Carbon Fiber Trunk weighs only (4lbs) and is secured by Quik-latch System
    -Full Carbon Fiber Roof panel shipped from Germany
    -Full Roll Cage custom made and welded to chassis along with rear Subframe system tie in.
    -MCS Single Way suspension with...…..
    Ground Control Camber/Caster Race Plates - E36 3 Series & Z3
    Eibach 2.25" Coil Over Main Spring
    6 inch / 800lb
    5 inch / 900lb
    2.25" Spring Thrust Sheet Set
    7-9.5" MCS-Specific Strut-Mounted Swaybar End Links
    12mm Spherical Rear Shock Mounts - E30, E36, E46
    Ground Control Rear Articulating Spring Perches
    -Eibach Front Sway bar
    - HARDMOTORSPORT rear 1/4 light weight poly windows
    - OMP 300mm Steering Wheel
    - LTW Wing
    - Diff's Online 3.73 with 3 clutch. Diff did not come with the speed sensor inside because I was going to use it with GPS Dash reader. Speed sensor can easily be installed.
    - DTM Fiberwerks fender flares. can run up to 295 slicks on 18x11 rims
    -18x11 WORK MEISTER S1 3 piece wheels powdercoated Satin black and semi gloss black
    -STOPTECH ST40 4pot BBK with Slotted rotors, OEM rear brakes with STOPTECH slotted rotors
    -Bimmerworld Carbon Fiber dive planes
    -New Stewarts Water pump
    -New Spark Plugs
    -New
    SPAL Fan Bracket and Strap Mounting Kit
    SPAL 16" Low Profile Fan - Push, Straight
    -New Coolant Expansion Tank
    -New Tensioner Pulley
    -New Valve Cover Gasket
    -New S54 Vanos Line
    -New Motorsports Thermostat
    -New Silicone coolant Hoses
    -New Front Strut tower reinforcement plates.
    * Take note car is completely gutted!!!!! I took everything out especially the rear bulk shelf wear the rear speakers sat. Even gave the wire system a diet. No HVAC, its sealed with HARDMOTORSPORT Block off plate. Dash board is out..i still have it if needed. All of the tar has been removed.
    Price - $24k FIRM!
    For pictures and videos please contact me - 914-659-7588. Serious buyers only. Apologies but have no idea how to post pics on this forum
    NY
    skateboard
    Finish it brah
    ― George Orwell
    Dec 2015
    westchester
    2011 E92 m3
    Fresh updates!
    Please don't hesitate to reach out to my cell phone to all who are interested.
    Dec 2015
    westchester
    2011 E92 m3
    bump
    Dec 2015
    westchester
    2011 E92 m3
    sunday bump
    Dec 2015
    westchester
    2011 E92 m3
    bumpp
    Dec 2015
    westchester
    2011 E92 m3
    bump
    Dec 2015
    westchester
    2011 E92 m3
    bump
    Dec 2015
    westchester
    2011 E92 m3
    Sunday Bump
    Dec 2015
    westchester
    2011 E92 m3
    bump!
  1. FS: E36 C-Mod, GTS3/4 Stickley motored race car
    By m3ltw98 in forum Race Cars & Track Parts
    Last Post: 12-23-2016, 02:18 PM
  2. E36 feeler - e36 M3 s54 Track/Race car
    By kenshin223 in forum Race Cars & Track Parts
    Last Post: 01-11-2013, 01:19 PM
  3. E36 FS E36 M3 H&R Race Springs & Rear FK Automotive springs with Adjustable Perches
    By BOOYAHH in forum Suspensions, Springs & Shocks
    Last Post: 04-23-2012, 09:40 PM
  4. E36 FS: E36 M3 H&R Race REAR Springs
    By AllGo'n'Show in forum Suspensions, Springs & Shocks
    Last Post: 08-16-2010, 11:45 AM
  5. E36 FS: E36 M3 Ground Control Race camber plates
    By All Motor in forum Suspensions, Springs & Shocks
    Last Post: 05-06-2010, 06:03 PM
