Results 1 to 6 of 6
Thread: Lower Timing Chain Cover Gasket Headache...
    Jan 2019
    Cottonwood, AZ
    1996 BMW Z3 Roadster
    Hey guys,
    I am having to replace the entire timing chain gasket... I have both timing covers (upper & lower) removed and I am about to reinstall the new gasket. Unfortunately I am having headaches with the rubber gasket that goes between the lower timing chain cover and upper timing chain cover.
    But the gasket is too small
    I tried stretching it to fit, but it always pops up before I can get the top half of the timing chain cover in place.
    I am hoping for an easy fix, was considering heating the gasket in the oven and then installing it before it can cool off.
    Any ideas?
    Thanks,
    J.
    Sep 2003
    kansas city
    98 Z3, 01 330i, 07 328iT
    Try a heat gun rather than the oven.
    May 2015
    Springfield Il
    '97 Z3
    Is this a BMW gasket or aftermarket? If it's aftermarket I'd get a BMW one. I replaced mine about a month ago and it was a perfect fit. As said before heat it up a bit before you install it. the upper cover has to be smashed down onto the lower cover to get it to seal correctly. Heating it up will make it more playable. I did not go the trick about heating it up before hand so I got the motor hot and tried to push it down. It still leaked a bit so smothered gasket sealer on the back edge.
    Oct 2012
    Louisville, KY
    1997 BMW Z3 1.9L 5MT
    Quote Originally Posted by nthor71783 View Post
    Is this a BMW gasket or aftermarket? If it's aftermarket I'd get a BMW one... I got the motor hot and tried to push it down. It still leaked a bit so smothered gasket sealer on the back edge.
    It does look too short to be a OE gasket. The
    Bentley Manual also mentions sealant, saying under "Install upper timing chain cover" to "Attach new gaskets to timing cover with light dabs of gasket sealant".
    BMW MOA 696, BMW CCA 1405
    Jan 2016
    Ca
    2001 525it
    Yea I would start with the factory gaskets, maybe a bit of silicone?
    May 2015
    Maryland
    1998 M Roadster
    Looks like the wrong part, do you have the P/N or the gasket and what year/engine is it going on?
  1. Lower timing chain cover gaskets
    By huesey1974 in forum 8 Series (E31)
    Last Post: 06-30-2011, 01:44 PM
  2. Lower Timing Chain Cover
    By sowilliams in forum 1991 - 1999 (E36)
    Last Post: 01-18-2008, 09:28 AM
  3. lower timing chain cover seal - procedure ?
    By BobCT in forum 1991 - 1999 (E36)
    Last Post: 09-11-2006, 08:21 AM
  4. Using M50 lower timing chain cover for S52 OBDI?
    By Hammdy in forum 1992 - 1999 M3 (E36)
    Last Post: 08-20-2004, 01:44 AM
  5. Need to remove lower timing chain cover....
    By e21pilot in forum 1975 - 1983 (E21)
    Last Post: 04-15-2004, 03:57 PM
