The AMP in my 2007 328xi wagon got some water on it and made some crackling sounds come from the speaker and a little smoke. BMW mechanic checked it over. The radio still works but I noticed that my subwoofers (under the seat?) do not. So the stereo sounds has almost no bass now. I bought a used AMP from Ebay that is from a 2007 328xi (E90). No one in the US was selling a used amp for an E91 exactly like mine, so the part numbers are not an exact match.
I have been told that the E90 amp will swap but just wanted to ask you all. Thanks for reading. I have satellite radio but no nav.
Hi,
Check realoem.com for part and revision numbers and cross reference for your car's build date. When you find the audio section, then any part and revision numbers listed should work in your car once you find replacements on forum classifieds and ebay etc.
If you find modules, then hopefully they'll work long term for you. If you can't find any, then you could either buy a new module from BMW or a discount genuine BMW parts specialist or, put in an aftermarket unit.
Cheers, Dennis!
Thanks Dennis
