H
wiring diagram I posted in your other thread https://www.bimmerforums.com/forum/s...ilter-fit-side
IHKA control module with the 4 plugs, next to the heater sword, here is the pinout
white connector X610 'A'
1-4 stepper motor fond area
5 heater sword
6 aux fan
7 rear window heater relais
8 climate control relais
10 NC
11 NC
12+F20 (30)
13+F20 (30)
14 - 17 stepper motors for air distribution (recirculation)
18 light switch LED
19 light switch LED
20 TXD
21 water valve left side
22 aux water pump relais K8
23 water valve right side
24 front window heating relais K8 , K8 connector X59 relay is in front/engine bay fuse box = front defogger/water pump relay, see page 0660-00 http://shark.armchair.mb.ca/~dave/BMW/e32/e32_90.pdf
25+F20 (30)
26+F20 (30)
Blue connector X613 "C"
Pins are in such way
13 up to 1
26 to 14
1= ground
2=ground
3= NC
4=temp feeler driver side
5= potentiometer blower motor
6= temp feeler in engine bay
7=outer temperature feeler
8= potentiometer temperature driver side
9=NC
10+,11+, for stepper motors
12+F21 (15)
13+ F21 (15)
14= ground
15=ground
16= potentiometer+ feeler ground
17= potentiometer flappers
18 temp feeler left
19 starter (50)
20=potentiometer+feed
21 temp feeler inside
22 temp feeler right side
23+ for stepper motors
24+for stepper motors
25+26 = F21 (15)
26+ F21 (15)
green X611 „B“
1 to pin 14,15,16
2,3,4,5 mixing flap motor left
6,7,8,9 fresh air stepper motor outside
10 NC
11 NC
12 NC
13 NC
14, 15,16 with pin 1 legroom stepper motor left
17, 18, 19, 20 defrost flap stepper motor
21, 22, 23 fresh air stepper motor left
25 NC
26 NC
yellow connector 614 „D“
1,2,3,4 legroom stepper motor right
5 MPX button
6 MPX button left
7 MPX defrost
8 MPX button right
9 speed signal
10 RDX
11 button rear window defogger/defroster
12 MPX button recirculation
13 MPX button aircon
14, 15, 16, 17 fresh air stepper motor right
18, 19, 20, 21 mixing flap stepper motor right
22 NC
23 NC
24 NC
25 NC
26 NC
The connectors are:
13 12 11 10 9 8 7 6 5 4 3 2 1
26 25 24 23 22 21 20 19 18 17 16 15 14
See the connectors, they are marked with small numbers outside.
the SWORD has a 5 pin connector
Pin 1 connector for the potentiometer for speed regulation at the control panel.
Pin 2 power supply
Pin 3: the relay get's contact when the blower fan potentiometer is adjusted, 12 volts come on.
Pin 4 is ground
Pin 5 the cable/wire from the blower fan.
I only worked once on the front windshield heater, found out that the connector left side bottom of the windshield was not connected, difficult to find, but check that first, here copied from Johan's site:
These are the terminals for the window heating, one at each side. It was just a wire and the terminal of the old shield has to be used: http://bmwe32.masscom.net/sean750/wi...ld/Image30.jpg
http://bmwe32.masscom.net/sean750/wi...ld/Image50.jpg
Connecting the lower window heater: http://bmwe32.masscom.net/sean750/wi...ld/Image86.jpg
indow heat element:
The lower part of the windshield in the area of the windscreen wiper blades is electrically heated to prevent the wiper blades from freezing onto the windshield. Heating is switched on at temperatures below 5 degrees Celsius and switched off at over 8 degrees Celsius. The control of this is done automatically by the climate control unit via the outside temperature sensor of the automatic climate control system. The control of the windscreen heating takes place via a relay in the power distributor. Control of the relay from the control unit is on the white plug, pin 24, cable BLUE / BROWN. The windscreen heater is not working in cycles.
See the diagrams in this link , section 5.7 and 5.8 http://www.e38.org/e32/klimaautomatik.pdf
