Maybe I missed something, have you defermined the FP doesn't run?
HF has a gauge with a lot of different fittings, think it's $20.
im sorry, i dunno why this thought got away from me here...hit the car with some starting fluid. if it tries to catch, its most likely a fuel problem. i shoulda thought of that right offa the bat here. "slaps self in the forehead...this aint a naturally receding hairline"
the hf gauge does have the fitting for a schrader valve. if getting it, make sure ya use teflon tape on the threads, elstwise itll leak.
yikes dennis...a 97 without ever having the need to replace the fp?
^_thanks.
My FP is original, got 158K on it.....knock on wood.
Going out to check now. I was just asking for recommendations just in case. My car has 175k on it. I'll let you know if anyone has been into the fuel tank yet!
I picked the car up last year. It's in great shape, I think the. Vanos have already been done. I have absolutely no rattle. The 2 things I have done are the CCV delete catch can replacement and rebuilt the DISA valve with new seal and aluminium internals.
Stay tuned.
84 528e
85 735i
03 530i
Ok the plot thickens....first off I had that HF fuel pressure kit already and I found all the fittings. I set may gauge up and went out to test and the results are.....
I have about 46 PSI with priming the pump and 50 PSI while cranking. It appears as if the pump is ok. Here is the strange thing. When I opened the hood I saw what looked like mouse bedding on the intake manifold right in the middle section. The section where there is a wire plug that goes to the injectors?. It was leaves and small twigs. Io have never anything get stuck in that spot before and the adjacent sections had no material. I also found more of this material down under the back side of the drivers headlight. If this little guy chewed a wire I can see that causing a the no start logically but what wire would that be?
Arrgg! I'm not 100% certain just going on what I see.
84 528e
85 735i
03 530i
Also the sound deadening under the back seat has not been disturbed on either side.
84 528e
85 735i
03 530i
ok your fuel pump is operating as it needs to be. can you post some pics of what youre seeing?
This is the last for tonight...I did a visual inspection of the engine bay wiring and all looks well that I can see anyway so maybe the mouse/rat idea is a little far fetched.
What could cause a no start when there is proper fuel pressure and an engine that is turning over? No spark? What should i check next?
Thanks!
84 528e
85 735i
03 530i
As said before the DME may not be released by the EWS (no spark or injector pulse). You need INPA to check that.
Or, unbolt a coil and stick a spark plug in it to see if you have spark.
And pop the cover off the injector rail wiring and see if you have injector pulse with a test light or multimeter.
How can I purchase INPA? Is the Ebay stuff ok?
84 528e
85 735i
03 530i
The cable is E-Bay (usually comes with a software disc) - cheap is fine.
Otherwise google Mike’s Easy Tools - extremely easy installation.
Mikes Tools are free? I still need the cable, correct?
Thanks, Rosie.
84 528e
85 735i
03 530i
Rosie, Chedley, Matt, thanks for the great info. I appreciate it! Learning more about this car all the time. Chedley, thanks for your download link. I may take you up on your generous offer to lend the "tools!" I just purchased a cable (K+DCAN with switch) on Ebay following you link, Rosie.
Thanks JimLev, Geargrinder and Dennis too! I'll still need help....
84 528e
85 735i
03 530i
power on reset, i believe, is from the battery going dead, possibly with the key being left in pos2. *researching*
84 528e
85 735i
03 530i
ok, your first pic shows the EWS recognises the key, but we already know that cuz it will turn over, and the DME is energizing the fp, cuz you have fuel pressure. in the 3rd frame, the line "EWS-Code unplausible" makes me think that the DME-EWS alignment is off (hoping GG will see this post and jump in with his depth of knowledge here) and that the DME is not allowing spark/injector function. checking for either spark (pull a plug, hook it up, ground it and see if theres spark) or injector firing (backprobing the connector). one thing might try is to disconnect the battery negative cable, turn the key to position 2 for 20 secs or so, key off, reconnect battery, and re-try. dont think this will reset the rolling code table, but its worth a try. still looking.
i think an alien craft must be flying around here somewhere, theres strange small pebbles of ice falling from the sky. those phanoramisis drives wreak havoc with the weather.
still researching
the error, not the spacecraft.
let the car go to sleep before disconnecting battery. open trunk, wait for trunk lite to go out, its then asnooze.
