Results 1 to 18 of 18
Thread: ECS SS brake lines on a touring or "are you sure these fit...?"
    Jul 2013
    Worcester, MA
    03 540i Msport Touring
    this may end up being evidence of my untimely demise in a few years but anyway:
    -engine bay brake line on my 540i decoupled rubber from its compression fitting and started leaking while i was on the highway, got home safe (in the cab of a tow truck)
    -replaced both engine bay lines and all four corners with ECS stainless steel lines, this exact set for $121
    https://www.ecstuning.com/b-ecs-part...it/e393430kit/
    -fully bled them, twice.
    the old lines have rubber grommets on them but i didn't see a way to get those off without destroying them, the new lines don't have any
    the rear lines' caliper connection is...strange looking, there's this really long solid metal standoff which doesn't give me warm fuzzies in terms of shearing forces. the other end of the connection is totally fine though
    ECS claims this fits the touring, and the new lines match the old lines' length pretty closely(see the q&a section of the above ecs link), maybe the standoff was just a cheap way for them to match length? i don't know
    braking test on jack stands is promising, pedal feel isn't any spongier than it was before and no leaks, pedal firms up perfectly when the car is off (another test for air in the lines)
    i'll update this as things get better or far worse.
    Looking for an e39 Touring black carpet set, including the rear cargo cubbies and side sections!
    ALSO looking for 540i 6speed manual transmission sets (2001+ pedals with switches, driveshaft, gearbox), for the 6speed swap! Probably not for a while....
    GN92489
    540i msport touring; jet black on grey
    Progress Thread (general)
    Progress thread (touring specific)
    Jul 2013
    Worcester, MA
    got some awkward on-the-ground shots. the line doesn't look as pinched as i thought it would, but still
    really wish i could find some shots of touring brake lines while on the ground, for comparison
    GN92489
    Jul 2012
    mitten
    525it,02 525it,73 2002
    I thought I read that the ECS lines didn't fit the touring. Couple people couldn't get them to fit.
    Jul 2013
    Worcester, MA
    the documentation is sparse, confusing, and mostly outdated (3+ years old)
    the UUC ss lines specifically call out not for use on tourings
    several other aftermarket lines don't explicitly mention the touring but don't say they're just for sedans
    to make things even more confusing, here's a set of rears from ECS that look different, but don't explicitly mention if they're touring or sedan specific
    https://www.ecstuning.com/b-ecs-part...027569ecs23~a/
    GN92489
    Jan 2015
    Tempe, AZ
    1995 525i/5
    Hm, sounds a little questionable. I used the Techna-Fit lines from FCP Euro and they matched the old rear lines perfectly in length and layout.
    1995 525i 5-speed - Thread
    Jul 2012
    mitten
    I think ECS had separate sedan and touring ss lines for sale,then they dropped the touring parts.
    I would call or email them to confirm they do indeed fit.
    Jul 2013
    Worcester, MA
    did a shakedown run last night, brake pedal feel is basically the same as before, not noticeable improvement sadly :/
    i'll contact ECS and continue to monitor
    to make things even more confusing, here's a comparison to the old line, they actually look quite similar in length?
    GN92489
    Feb 2014
    Alexandria, VA
    ‘01 540’00 528T’03 525T
    When I shopped around, the ECS lines were only for the sedans, that’s why I got mine from FCP.
    Jul 2013
    Worcester, MA
    Feedback direct from ecs just now;
    "Hello,
    After looking over the photos, it may look pinched but it is not. We have tested this kit on touring models and have had to other issues. Thank you "
    So looks like the answer is yes, with testing included.
    Still, I'm going to keep an eye on these things....
    GN92489
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    Quote Originally Posted by joekitch View Post
    We have had to other issues? Werrrt?
    We have had two other issues?
    We have had no other issues?
    We have had to otter tissues?
    By the way I can't see any pictures here. Tried a few tricks, dunno what it is.
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    Yeah, that ecs reply is not a ringing endorsement.
    Jul 2013
    Worcester, MA
    no other issues, i make that typo occasionally too
    they're pasted from google photos
    do you have https://lh3.googleusercontent.com blocked by some adblock?
    GN92489
    Sonoma Whine Country
    E12, E12, E36, E39
    I'm not seeing any pics either, Google isn't known for playing nice with forum software. I use imgur.com or postimages.org
    On your link, all I get is
    404. That’s an error.
    The requested URL / was not found on this server. That’s all we know.
    98 328is
    02 525ita
    80 528i
    81 528ia
    and decades of owning and driving BMWs
    Jul 2013
    Worcester, MA
    guess i'll need to download locally and attach to the post instead. rip
    GN92489
    Jul 2013
    Worcester, MA
    and done, they should all be visible now
    GN92489
    Aug 2016
    Virginia,USA
    528i, 525iT, M5
    When I went down this path in 4th Qtr, I could not find anyone who made the rear lines for a wagon that matched length and fit. If anyone finds some one post a link.
    Never mind found it: Techna-Fit 540 E39 wagon stainless lines F&R plus the short master lines under the hood!
    http://www.technafitstore.com/BMW-Br...p/bmw-1225.htm
    Current Garage Highlights
    2003 525iT TiSilver
    2002 M5 TiSilver
    Former Garage Highlights
    2005 X5 4.8is
    2004 325iTs (2x)
    1973 Pantera L
    1969 Road Runner 383
    Mar 2010
    Quote Originally Posted by StephenVA View Post
    In fact I think I might have those. Id have to check the records but that brand sounds right but purchased on sale via ECS or FCP or some other 3-letter acronym.
    2003 M3CicM6 TiAg
    Former:
    Jul 2013
    Worcester, MA
    request to pop your phone between the spokes of your rear wheel and snap a pic of the lines, to see how they sit when the car's on the ground
    i'm starting to suspect that this level of curvature on the line is totally normal and fine
    GN92489
  1. E36 New ECS tuning SS Brake Lines
    By sar5036 in forum Brake Kits, Rotors & Pads
    Last Post: 04-21-2013, 05:49 AM
  2. For those interested in SS brake lines --->>>
    By Cobra Jet in forum Group Purchases & Supporting Vendor Specials presented by eBay
    Last Post: 09-13-2002, 04:50 PM
  3. BavAuto service/ss brake lines....
    By BS05ZHP in forum Vendor Comments & Supporting Vendor Info
    Last Post: 06-24-2002, 09:12 AM
  4. Replies: 0
    Last Post: 06-11-2002, 06:51 PM
  5. Anyone Use Techna-Fit SS brake lines?
    By bblars in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 11-13-2001, 10:55 AM
