What is going on with this error? Using bimmergeeks tools and datens, my cable works with winkfp and inpa.
My copy of ncs has manipulation mode and factory mode only, so I changed the profile settings of manipulation to meet those of expert mode, at least as much as I could.
Every time I select e46 to get the cars VO I get a coapi2020 code... any help?
Honostly I didn’t even read the error parameters (i never do if it is longer than 7 lines!)
Just the way it looks (from my ignorant point of view) like communication failure which could happen when;
-you did not turned your key to the position 2
-obd2 or 20pin connectors have a problem
-old car with not soldered cable or new car with soldered cable
(if a switched cable is being used switch is on the wrong side)
-cable driver is not set to same port selected when installing standart tools (usually COM1)
-cable driver latency setting is a value different than 1
I believe it ended up being my cable, my current one works with inpa and everything but ncs. Borrowed one from a friend and it was all good
why is it when I go to GM5 C01,C02,C03,C04,C05,C06. I am getting this message
a RED( X )come up 15:45:29 An error occurred while reading "C:\NCSEXPER\WORK\FSW_PSW.TRC": Unresolved parameter
keyword "500ms" in function "HUB_VERZOEGERUNG_FH_VORN". Make sure chassis and module match those of the trace file.
knowing I have had GM5 C01 & C06 working befor but now all of them are not ? so I can get back to codding
