Results 1 to 20 of 20
Thread: Previous Owner JB welded Tranny Drain Plug... Ideas?
    Madison, WI
    2003 M3, 1998 M3 TS
    Well fun times, I got under the new to me m3 and found the transmission drain plug JB welded shut. It also appears to have a small leak coming from somewhere.
    Either way, any ideas on how to drain and fill the transmission without using the drain plug?
    2.1L Eurosport Twin screw on the 98 m3. Please send tires.
    Valencia, CA
    Imola E36 M3 E30 Touring
    Heat plus impact gun?
    Otherwise, drill it out and re-tap with a larger thread.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Get a large size cement mixing tub from Home Depot for a few $. Position it under the ATF pan, and then losen all pan bolts so that the pan and the ATF drops into the cement tub. Clean the pan and inspect it, much easier to inspect and repair the bolt when you have the pan out.
    Jan 2019
    houston
    2017 F150, 97 M3
    If the fill plug isn't j b welded shut you could potentially suck the fluid out of the fill plug, although I'm not sure what kind of room there is to fish the hose deep into the transmission, may have to try a smaller than normal sized hose. I would be scared of using an impact on that plug, could crack the transmission potentially. It may have been j b welded because of a crack already, why else would it be j b welded?
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    I think the JB Weld might break free. I’d be tempted to try, but be prepared for a mess and dealing with a repair/replacement.
    RRSperry's Avatar
    RRSperry is offline Senior Moment Member BMW E36 M3 Expert
    Mar 2002
    Eldersburg, Md
    95 ///M3sc, '21 C8 HTC
    Heat, lots of heat... Preferably Oxy- Actylene, or an induction heater, but the JB weld will eventually give up.
    Now the question is why the JB weld?
    Both the fill and drain plugs are pipe threads so there's not a sealing washer. Did they crack the transmission case?
    Jul 2005
    Albuquerque, NM
    '77 turbo 320i, '07 Subi
    Shogun is on the right track - I've tried suction methods with minimal success. Too much heat might warp the pan, but maybe not if it's localized.
    MauiM3Mania's Avatar
    Jan 2002
    Central Pacific
    88M3 99M3 04M3 ITBx16
    Wait... forgive me, it's still early here, but are we talking about a manual trans of auto?
    88M3 AW 43k miles Project FS
    Austin, TX
    E36M3, E60545i, F10550i
    Quote Originally Posted by MauiM3Mania View Post
    Both, it seems.
    Jun 2005
    New England
    It’s a convertible so I will guess 50/50 chance of auto. That is why my response was transmission-neutral.
    RRSperry's Avatar
    Mar 2002
    Eldersburg, Md
    Eh, M3 probably not an automatic...
    Jan 2005
    Japan
    wait.... looks like the E36 M3 forum is the wrong forum, I just see
    My Cars: 2003 M3 Vert
    E46 ?
    Jun 2005
    New England
    Well, that changes everything about how to remove jb welded trans drain plug.
    RRSperry's Avatar
    Mar 2002
    Eldersburg, Md
    Lol.. yep, all the difference...
    Oct 2003
    Seattle
    99 M3
    Quote Originally Posted by RRSperry View Post
    Ya, for an auto, replace the pan.
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    Quote Originally Posted by bluptgm3 View Post
    Well, to be serious for a second before we go off the rails, an "auto" E46 M3 is an SMG, which is to say there is no difference. It's the same transmission as the manual. Certainly no pan on it like a real automatic.
    ... and we're back where we started - no pictures or response from the OP while we all theorize on just how bad / extensive this JB Weld job is and how to attack the thing.
    And now we're not even sure if it's an E36...
    Jun 2005
    New England
    This is getting more interesting all the time.
    washington dc
    Avus Cosmos Calypso!
    isn't jb weld just epoxy? That bond is far less strong than say steel....should be able to break that drain plug free just by hand...worst case use a cheater bar.
    Jan 2002
    outta SoCal, now CO
    '98 M3 Alpine White
    Aluminum pan? Drill it, then Timesert. Better off, anyway.
    Auto and steel pan. Well, it's lifetime fluid, right? Good luck!
    See ya later,
    tony
    '98 M3, '92 Dinan3, '05 R1100S BCR, '07 R1200S, Aprilia T
    Aug 2013
    1999 BMW M3 Coupe
    Quote Originally Posted by scooper View Post
    Yeah I agree. The stuff is strong for sure, but it will break loose with enough torque. As others have said, some careful application of heat to get the bolt up to at least 200-300F might help. Then, it's just a matter of a long breaker bar, pipe, and maybe a helper. Probably easiest on a lift, or very high/secure jackstands.
    Also, whoever does something like that should be shot. It probably just needed a new washer or plug, and they went straight to JB-Weld. If they wanted/needed to put some sort of sealant in there I'm sure the black Permatex stuff you use on oil pans and whatnot would've worked fine. Lifetime fluids I guess...
  1. 540i auto tranny : drain plug seal ? tools ?
    By js22 in forum 1988 - 1996 (E34)
    Last Post: 09-22-2010, 12:48 PM
  2. 1987 L6 Tranny drain plug
    By Therron in forum 1976 - 1989 (E24)
    Last Post: 07-13-2009, 12:48 PM
  3. mess up big time, tranny drain plug stripped
    By gumbee in forum 1999 - 2006 (E46)
    Last Post: 10-13-2007, 05:42 PM
  4. Lost the radiator drain plug... Ideas?
    By MR 325 in forum 1983 - 1991 (E30)
    Last Post: 07-09-2006, 09:53 PM
  5. is there a tranny drain plug crush washer?
    By TXBDan in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 01-23-2006, 03:47 PM
