Results 1 to 10 of 10
Thread: Expansion Tank Conditions
    Jan 2019
    San Francisco, CA
    2004 325i, 1999 Z3 2.3
    Question Expansion Tank Conditions
    2004 325i, 97k miles.
    Due to a small collision I recently had to fix the front, including replacement of radiator, vent, expansion tank.
    The body shop did a good job, in my opinion, but to keep cost lower they used a "pre-owned" expansion tank.
    My mechanic just declared the new old tank a pending disaster and is begging me to replace it.
    He especially mentions the brown color of the top hose as a sign of degraded state.
    I'm not expert enough to judge. If he had not said anything, I would not have been questioning the part
    I'm enclosing a link to a picture.
    http://i64.tinypic.com/j9sf7r.jpg
    He's asking ~$700 for the job, including $320 of parts.
    Dunno, ECS sells a complete kit for less than $150 and even just the $42.48 for a gallon of coolant seem way high.
    I'd be grateful to anyone who wanted to weigh in on the hose/tank conditions and the cost of replacement.
    I know this is a weak spot of the E46. Would keeping a close high to water temperature be enough to diagnose a failure before car is damaged ? The needle has never gone past midway, so I naively imagine that shutting off the engine as soon as it does would be good enough.
    TIA
    Mar 2018
    Millis, MA
    2002 325xi
    That brown you see, is not part of the expansion tank. I think it's the return hose? It brings back excess coolant to the expansion tank. (Part #1 on this diagram: https://www.realoem.com/bmw/enUS/sho...diagId=17_0215) However, since most of the cooling system on these cars are plastic, you should definitely look into replacing that bit at the very least. It's something anyone can do because of the easy clip-on nature of that hose. No mechanic needed for that.
    Shame on you for getting a "used" expansion tank, though. They're relatively inexpensive on their own, so there isn't really a need to go used. If I ever need a mechanic to do work for me on my car, I usually try to buy the parts myself because the garages will absolutely annihilate your wallet on overnight shipping costs and such. I also don't see how replacing the expansion tank and return hose would cost more than 1 hour in labor. Find a different mechanic.
    Jan 2019
    San Francisco, CA
    Thank you.
    Yes, I had in mind to at least change the hose myself.
    Agree on the fact that it would have made more sense to use new parts.
    It was out of my control. Body shop got some used parts to fix extensive front damage after collision and, although they got new radiator and fan, decided to use that expansion tank assembly (I imagine from the same junk that generated the front bumper and lights).
    I found a comprehensive video step by step of the entire tank replacement on youtube. It looks like an hour job and I'm going to get a second opinion from another mechanic.
    Jan 2016
    Ca
    2001 525it
    Brown is not good New is black
    Michigan
    2005 325Xi
    $700 had better include a new t-stat and waterpump too.
    Quote Originally Posted by B4SH View Post
    If anyone knows, it's this guy who knows literally nothing about everything.
    Quote Originally Posted by fcvapor05 View Post
    Do you even OT? The mean 401k around here is probably about $6, what with all the shiny cars and $1,000 watches and donations to get other members' Volvos running.
    Jan 2019
    Massachussetts
    2000 M Roadster,e46 325i
    If you research this job enough you will find alot of recommendations to replace all the cooling system components while you are at it. This is sound advice, especially if you are paying a shop to take care of this type of thing. Personally I chipped away at it, and regret that decision. Basically each summer over the past few years i replaced the thermostat, water pump, radiator, several hoses in turn drain and fill each time. With the info out there this is definitely something that can be done at home.
    I'm not really good at estimating shop fees but $40 for coolant is about a 2x markup on that alone. FCPeuro offers free shipping over $50 and, believe it or not, will take back any failed part that you buy for them for any reason with no hassle at all.
    Good Luck
    Jan 2019
    San Francisco, CA
    Quote Originally Posted by Critter7r View Post
    Doesn't include squat: just tank, upper hose, coolant refill.
    I'm getting estimates from others this week. Based on those I may only replace the upper hose myself (hopefully without having to remove the air box), or do the entire system.
    Thank you all for the advice.
    i
    Apr 2015
    Netherlands
    2000 E46 328i
    Don't forget to replace the cap on the expansion tank aswell
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    OP, try www.bimrs.org to find a reputable indie shop that specializes in bimmers. $700 to replace the tank and the upper hose plus coolant is a ripoff, even for The City.
    Jan 2016
    Ca
    2001 525it
    Only use the factory expansion tank, mounting plate and hardware, not china made crap
  1. E36 coolant expansion tank & cap
    By nat325i in forum BMW Parts For Sale
    Last Post: 01-18-2004, 05:51 PM
  2. M42 "Lower expansion tank seal"
    By Bimmubishi in forum 1983 - 1991 (E30)
    Last Post: 01-11-2004, 04:45 PM
  3. Anyone make an aluminum expansion tank?
    By ChicagoE38 in forum 1995 - 2001 (E38)
    Last Post: 12-30-2003, 12:06 PM
  4. DIY Expansion Tank Change Anyone?
    By RRdawho? in forum 1991 - 1999 (E36)
    Last Post: 07-11-2003, 04:56 PM
  5. radiator and expansion tank replacement
    By sealbeach740 in forum 1995 - 2001 (E38)
    Last Post: 04-22-2003, 08:27 AM
