RM European Auto Parts
Results 1 to 12 of 12
Thread: CV joints, help
    Feb 2019
    NE Ohio
    2015 528i xdrive
    CV joints, help
    Hi all,
    I have a 2015 528i xdrive. I noticed when I turned right from a stop, a clicking noise. CV joints, my mechanic says. I do not want to replace the whole axle due to the cost. Rather, I would like to rebuild/replace the joints and boots. Any ideas where I could find the joints online? I have access to a shop and tools.
    I assume because its clicking, I cant replace the boot, grease it up and save it. Correct?
    I just dont want to spend a fortune on the axles.
    Jul 2004
    Houston, TX
    36 Cylinders
    How many miles?
    Although it's true that it can be axles making that noise.. it can also be something else, such as the 4wd system.
    CV joints are expected to wear and click with very high mileage.. very unusual for a 2015.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    In my estimation: If the boot is torn badly, and the joint is clicking and dry, the axle is done, and should be replaced with an OEM axle. It will likely be made by GKN, and FCP Euro will be a good place to get it.
    Left: https://www.fcpeuro.com/products/bmw...kn-31607618681
    Right: https://www.fcpeuro.com/products/bmw...kn-31607618680
    Hey, they're $700 each cheaper than the BMW labeled part, made in exactly the same factory by exactly the same manufacturer.
    Chris Powell
    BMWCCA 274412
    Feb 2019
    NE Ohio
    2015 528i xdrive
    Thanks all, it has about 80k.. I replaced the axle and the noise still exists.. it's the worst when I back up
    Jan 2016
    Ca
    2001 525it
    Have the tech lift the car and search for the noise while it's running
    Michigan
    2005 325Xi
    CRACKING NOISES FROM THE FRONT AXLE AREA WHILE TURNING THE WHEELS, WHEN
    STATIONARY OR PARKING
    Situation : Cracking noises are heard from the front axle area while
    maneuvering at low speeds (e.g., parking lot maneuvers) or when turning the
    steering wheel while stationary.
    Cause: Movement between the contact surfaces of the wheel
    bearing and swivel bearing (knuckle)
    Procedure : Confirm the noise is coming from the front wheel
    bearing area and remove the front wheel bearing. Use repair kit P/N 83 19 2 298 825 to
    clean up the mating surfaces of the wheel bearing and the swivel bearing (steering knuckle).
    Feb 2019
    NE Ohio
    2015 528i xdrive
    It's not really a cracking. Sounds like metal on metal, grabbing and releasing
    Michigan
    2005 325Xi
    Quote Originally Posted by berggerm12 View Post
    Imagine a big hunk of metal machined to fit precisely and soooper tightly into another. Except one of the pieces was spec'd a couple hundred thousandths too big (or small) and imagine the noise that would make under stress.
    That's the noise.
    Feb 2019
    NE Ohio
    2015 528i xdrive
    Quote Originally Posted by Critter7r View Post
    That's the noise.
    Touche! Thank you very much. What does the kit contain? I havent found much information on it? Will get the repair kit and update once it arrives.
    Feb 2019
    NE Ohio
    2015 528i xdrive
    I found the kit. It contains essentially sandpaper and wheel bearing grease. Could I goto autozone and pick up said grease and I have sand pads at the house?
    Michigan
    2005 325Xi
    It's a 2-part grease that dries slightly tacky. I can't confirm whether or not regular grease would do the job. But sand and put the grease only on the flat, narrow mounting surface of the wheel bearing assy that connects the mounting bolt holes, without getting any into the holes or onto the bolts. Then sand and clean (but DO NOT GREASE) the inner mounting surface of the brake rotor.
    Jun 2002
    E39M5, E500 4WD
    I just reread your first post. Does this noise happen when you turn the steering wheel when the car is not moving? Just checking.....
    Chris Powell
    BMWCCA 274412
  1. Driveshaft cv joint help
    By TylerG21 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-12-2012, 04:12 PM
  2. 95 m3 Drive shaft cv joint help
    By TylerG21 in forum 1991 - 1999 (E36)
    Last Post: 11-10-2012, 08:57 PM
  3. cv joint help
    By dub 6er in forum 1976 - 1989 (E24)
    Last Post: 11-08-2010, 07:15 PM
  4. CV Joint Help
    By skinbones in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 02-06-2010, 02:04 PM
  5. outer CV joint help
    By jmitro in forum 1992 - 1999 M3 (E36)
    Last Post: 05-24-2006, 11:08 PM
