Results 1 to 8 of 8
Thread: 1995 850ci Thermostat replacement
    Apr 2015
    NJ
    1995 BMW 850ci
    Looking for help to replace thermostat, just line by line instructions on how to get to it.
    Am i going from top or bottom, everything seems to be in the way (
    Repairpal claims its about 1 hr job.
    Thanks!!
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    did you check the workshop manual? https://www.bmwtechinfo.com/repair/main/721en/index.htm
    Apr 2015
    NJ
    1995 BMW 850ci
    Perfect!! ♥ 🙏
    Apr 2015
    NJ
    1995 BMW 850ci
    Took the fan out using the clutch and 32mm wrench tool, it was quite easy.
    I have taken the thermostat out, and realized the new Wahler Thermostat
    has 90 degree written on it, while the old one has 95 on it. Is this still ok ?
    Apr 2015
    NJ
    1995 BMW 850ci
    No time to think too much, new thermostat works, and i get full heat now with engine temp holding constant in the middle of the Guage. Looks clean.
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Antiseize
    Did you put some antiseize on the fan threads for next time?
    Apr 2015
    NJ
    1995 BMW 850ci
    Quote Originally Posted by rjjablo View Post
    The fan came out very easily. The 32mm nut wasn't tight and very light torque loosened it.
    Is the anti-seize necessary ? I usually spray on PB Blaster and let it soak if I can't get
    something to turn with decent torque. But I Had a difficult time trying to screw back the
    fan. I don't know how large sized people with big hands can do this lol.
    I checked the coolant level after the refill, and had to top off with about half a quart
    this morning. Car heats up in about 2 mins of drive.
    I still have to figure out the misfires !!
    Can't believe its been 4 years and I haven't fixed this:
    https://www.bimmerforums.com/forum/s...ight=sshivaram
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Anti Seize
    Anti Seize is not necessary until it is necessary, I use it as insurance either for myself or the next guy. Took the fan off mine with these tools.
  1. quick help wqith 1995 m3 thermostat
    By cheddafob in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-03-2003, 09:29 PM
  2. thermostat replacement???
    By steve m3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-05-2003, 02:43 PM
  3. Thermostat Replacement
    By Josh328 in forum 1991 - 1999 (E36)
    Last Post: 02-21-2003, 10:56 AM
  4. Thermostat replacement?
    By JST in forum 1992 - 1999 M3 (E36)
    Last Post: 02-10-2003, 11:30 AM
  5. Thermostat replacement question
    By m3sailor in forum 1992 - 1999 M3 (E36)
    Last Post: 01-09-2003, 10:03 AM
