Just finished these guys up today. Pretty good use of a day of rest I would say.
Same deal as last time, we scanned the OBD1 Cover and designed it to fit exactly.
These will, again, be laser cut and CNC bent out of vinyl wrapped stainless.
Stainless is the preferred material when it comes to protecting against radiant heat!
If anyone is interested Ill be taking limited pre-orders for these for the next 3 weeks at a reduced price. I will have these quoted on Monday, but expect pricing to be similar to last time.
The final product will look similar to this:
Running list for the preorder for BFC:
1. Callmepuff
2. Mithclevy7
3. lbennyboobool
4. Parallel
5. Dankeen
1989 535i - sold
1999 M3 Tiag/Dove - sold
It should be vented on the top give the heat some place to go
1989 535i - sold
What's the price on one of these bad boys? And do they all have the M emblem?
Sent from my Pixel 3 XL using Tapatalk
'95 E34 525i, M50B32 (S52 Crank, K1 Rods, JE 9.0:1 Pistons, S52 Cams, Cutring, Achilles Oil Pump Shaft & Sprocket), GTW3684R 0.82A/R, ZF320
1989 535i - sold
1989 535i - sold
Interested
I vented my plastic cover on each side of the mounting bolts, there has to be a lot of heat down there no wonder coil packs fail.
Many of us using these would need a space for the coil pack wiring to pass though near the coil cap.
put me down for 1.
awe i wish it would have the M logo like the obd2 version
Count me in on one though
1989 535i - sold
1989 535i - sold
While I see what you are after, have you considered the following?
An engine is thermostatically controlled to around 80c in normal operating conditions. Meanwhile exhaust temperature wildly exceeds 80c. This exhaust heat is radiated off into the engine bay. This radiant heat is even greater in a turbo application, especially a top mount.
With that said it is our contention that radiant heat in the engine bay will always exceed the temperature of the valve cover; therefore, We only need to protect the coils, wires, gaskets, and other composites from direct radiant heat.
1989 535i - sold
Funny Coincidence, I was just wondering if someone was going to make an OBD 1 version. Let me know where to pay when ready.
Sent from my Pixel 2 XL using Tapatalk
I’m interested let me know how and when to pay
Could a Knurled button style nut be created for this for easy removal?
1989 535i - sold
Hey Vollosso, what's the status on these guys?
1989 535i - sold
I made my own out of aluminum and covered in gold heat tape. it turned out great, but it was a ton of time invested to get it bent, fit and trimmed right. After personally doing mine and knowing what goes into it I'd say your sitting a great price for a bolt on part!
need and obd1 asap.put me down for one vollosso.thanks
1989 535i - sold
