Results 1 to 7 of 7
Thread: 2014 435i hard down shift when vehicle is cold
    Oct 2012
    Savannah, GA
    2001 330ci
    hey folks, need some help/advice......
    I just bought a 2014 435i. 51k miles, not that is matters but m sport/brakes/and m suspension
    8 speed automatic
    I really want to like this car.... BUT
    When the car is cold (has sat overnight), when I go to the end of the street (maybe 200 yards) in normal Drive, and in comfort....as I approach the stop sigh at the end of my street when it downshifts to from 3rd to 2nd and then from 2nd to a complete stop...it downshifts hard - it is very annoying but not a deal breaker. I had a indy shop flash it but it almost feels worse - I am going to have the flash removed and then take it to my dealer.
    Also, at times, when I am turning (I know that probably has nothing to do with anything) and getting on the gas it hesitates....
    My question is this:
    Has anyone has anything similar to this happen and did software help or fix it?
    I am sure I can get it to do it for the shop, are they going to tell me this is normal?
    OK, thanks!
    Denver, Colorado
    MRster / Z4 M4i / X5 M50
    You need to make sure they pull the codes to see if the car knows about something that is not working correctly.
    2002 M Roadster, Steel Gray Metailic, Gray Nappa Leather, Black Soft Top, Steel Gray Metailic Hard Top, TC Kline Double Adj Shocks with H&R Springs, Stromung Exhaust, SSR Type C Wheels. Looking for a new home.
    2022 Z4 M40i, Misano Blue Metallic, Prem Pkg, Driver Assistance Pkg
    2023 X5 M50, Phytonic Blue, Black Extended Merion Leather, Driving Asst Pro Pkg, Park Asst Pkg, Exec Pkg, Climate Comfort Pkg.
    Oct 2012
    Savannah, GA
    2001 330ci
    I have a fairly good scanner. It does not have any codes in any modules
    Jul 2004
    Houston, TX
    36 Cylinders
    That isn't normal, I would scan it with a scanner that reads BMW manufacturer codes, and/or take it to a dealer or experienced BMW independent. A scanner that reads P codes is not appropriate for this. There are around 20 modules in your car and you will have codes for something. The car stores everything, every little fault from the past. Also, a BMW oriented scanner can view a lot of extra live data needed to be able to diagnose.
    A fluid change doesn't fix broken things, but it may be worth doing.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Oct 2012
    Savannah, GA
    2001 330ci
    My scanner interfaces with all the modules, I didnt have any trans or DME codes
    and at 51k miles should not need fluid already
    Jul 2004
    Houston, TX
    36 Cylinders
    Ok, dead end answers. I tried.
    -Abel
    Michigan
    2005 325Xi
    Quote Originally Posted by geoffriehl View Post
    What he's telling you is that an OBD scanner has only the functions mandated by law. A scanner at a dealer or good indy shop WILL find faults stored, and they may point to something going on. Or not. Depending on the severity, it may just be something that happens in cold weather. Or the PO may have put new (and possibly incorrect) trans fluid in it, or flashed the trans for firmer shifts. And no, you *shouldn't* need new trans fluid at 50k, but ya never know.
    Quote Originally Posted by B4SH View Post
    If anyone knows, it's this guy who knows literally nothing about everything.
    Quote Originally Posted by fcvapor05 View Post
    Do you even OT? The mean 401k around here is probably about $6, what with all the shiny cars and $1,000 watches and donations to get other members' Volvos running.
  1. hard down shifting
    By scott99540it in forum E39 Touring / Wagon
    Last Post: 04-24-2014, 03:57 PM
  2. Hard down shift after filter replace
    By cdk348 in forum 1995 - 2001 (E38)
    Last Post: 12-30-2011, 10:35 AM
  3. 2002 525i hard down shift to 1st
    By SMOKEYBMW in forum 1996 - 2003 (E39)
    Last Post: 07-31-2011, 11:39 AM
  4. Hard Down shift
    By Cbreeze in forum 1996 - 2003 (E39)
    Last Post: 05-06-2011, 12:45 PM
  5. hard down shift to 1st in auto tranny
    By ataie in forum 1999 - 2006 (E46)
    Last Post: 03-08-2010, 04:41 PM
