Bimmerforums Upgrade Garage The Tire Rack
Results 1 to 3 of 3
Thread: 535xi wheel and tire upgrade
    Jan 2017
    Evansville, Indiana
    2008 BMW 535xi E61
    Have a 2008 535xi touring that I would like to upgrade to 19" wheels. Have 19" wheels chosen at 8.5 and 35 offset, but not bought yet. Most fitment programs are good with 245 35 19 for tires, but would like to go to 245 40 19 to fill the wheel openings better. Would really appreciate any input from experience with either size tire. Thanks very much.
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    If you change wheel diameter by an inch but do not change sidewall or width, you should expect the tire to grow by about an inch, from 25.7 to 26.7. I have not tried this fitment, but would put my car on a drive-on lift and turn the wheel from lock to lock to look for rubbing. Probably on a stock ride height car, there would be no issues but I would want to try to check before buying. If lowering or changing wheel offset, there could be issues. The speedo error is not bad — 60 mph might show up as 62-63 mph. 5 series dot net might be more active.
    Aug 2002
    South Bend, Indiana
    BMW 525I
    Keep in mind you will be changing the speedometer, odometer and gear ratio if you go with the bigger 245/40R19 tires. They may clear but could rub under suspension travel.
    If I can help let me know.
    If ordering through the web site click through one of the banners and list "Jim" as a previous contact. The Tire Rack will direct a portion of the proceeds back to the the Bimmerforums.com site.
    Tire & Wheel Forum sponsored by The Tire Rack
  1. Considering a wheel and tire upgrade for my e36 track car
    By adept in forum Track, Auto-X & Drag Racing sponsored by Bimmerparts.com
    Last Post: 03-28-2018, 08:12 PM
  2. E24 Wheels and tires -upgrade to 16 450.00
    By billbarr in forum Wheels and Tires
    Last Post: 09-24-2013, 06:38 PM
  3. 83 e21 wheel and tire upgrade
    By komv7919 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 02-02-2009, 09:30 PM
  4. 18" wheel and tire upgrade
    By BoardNFlip in forum 1992 - 1999 M3 (E36)
    Last Post: 07-02-2005, 07:19 PM
  5. How much more grip for wheel/tire upgrades??
    By H&RMcoupe in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-06-2003, 04:52 PM
