Page 2 of 2 FirstFirst 12
Results 26 to 50 of 50
Thread: Electric fan Conversion gone wrong!
  1. #26
    Oct 2012
    Detroit, MI
    E36, E70, i3
    Here's a thread: https://r.tapatalk.com/shareLink?url...9&share_type=t
    Hope that works.
    Note the range from center mark to first tick after is 20 deg F (from 190 F at center to 210 at first tick). That's AFTER removing the buffer. Hence built in buffer is something greater than 20 deg F.
  2. #27
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    Maybe the buffer is 170-230F. Whatever it is, it’s broad enough that your car is either too cold or at risk of overheating if the needle is moving. I think you can watch on the obc by unlocking it and entering a certain code. I have another gauge in my car but maybe the sender is not accurate.
  3. #28
    Jan 2019
    HK
    Wow that's alot of new info. Didn't know that the temp actually went all the way to the red before coming back to centre. Guys, would you know the exact temp that is supposed to be engine optemp? Ignoring all buffers etc, what is operating temperature exactly ?
  4. #29
    Nov 2016
    texas
    1998 328is
    Quote Originally Posted by Nanniepoo View Post
    M50 uses two different engine temp sensors, one for DME, one for instrument cluster. M52 uses one temp sensor and signal is split in the harness going to DME and cluster. Radiator temp switch is completely different.
    Accuracy of the sensor does not imply accuracy of the gauge.
    I don't know the specific numbers of the buffer range but I'm sure the data can be dug up somewhere on here. There's at least one thread about how to remove the buffer, wouldn't be surprised if the info is in there.
    so the temp sensor that is located on the head of the m52 is for the dme right? which sensor is for the gauge on your dash then
    ok guys lets just say we dont want our cars temp gauge to be in the red or even past the middle, soon as i see the gauge creep past the middle i turn the engine off, even if im rolling down the road i push clutch in, key out and come to a safe stopping place. id rather be stranded then wrap the cylinder head, usually when you exceed 225f the gauge will start to move past middle, and when you are at 250f its in the red. sadly i cant test my electric fan since my fuel pump died . was thinking of taking the aux switch out and putting it in a bucket of water of 220f to see if relay activates.
    98 328is/5 Arctic silver
    99 528i 5speed Alpine white(Totaled Unfortunately)
    Oil pan and timing chain delete, weight reduction right?
    98 540i/6 (New baby)
  5. #30
    Jan 2019
    HK
    You should stop the engine if its in the red or threatening to get there, but before that its a matter of concern but there is no need to go all emergency on it. I would only go emergency mode if it hits 3/4 and I don't know why.
    That cylinder head and block is strong. Many people who come onto the forums - we get a warped view of the probabilities. I mean like only people with problems will make posts here. After awhile you will naturally think the car is full of problems. Yet as a percentage of the total E36s on the road it might not be significant at all. Those cases where someone just touches red and the head goes - doesn't square with reality. UI've overheated my M50 several times before with no problems, and this is with an alloy head but cast iron block - higher risk of cracks due to differential expansion. Not the problem with the M52/54 as I understand it.
    I'm sure touching head and all hell breaks loose does happens but it would be very obscure. And remember we don't know the detailed history of the car in question - all that would be highly relevant imo.
    An abundance of caution never hurt anybody. My comments here are not a judgement on that.
    And you don't need the fuel pump to test the aux fan. It is purely electrical. Just put the key into position 2, then pull the connector from the radiator's double temp switch, and jump the internal sockets. You should hear the fan running at low and high speed. The double temp switch can be tested by checking continuity when you put it in hot water. Or you can create a run hot situation temporarily on the car. At just past middle, definitely by the time its between middle and 3/4 the high speed aux fan comes on. Then as it runs and cools the radiator down, it will switch to low speed, and then it will shut off.
  6. #31
    Nov 2016
    texas
    1998 328is
    Quote Originally Posted by Thomas525 View Post
    the head is strong yes but unless you have the m50 which is cast iron head, all m52 and 54s have aluminum heads so i assume the aluminum is going to crack or wrap eventually even after being 20 yrs old. you also lose bit of compression by overheating it. so when it happens to me i find the next exit and shut it immediatly
  7. #32
    Jan 2019
    HK
    The m50 has an iron block. The head is aluminium. Actually all the heads and blocks (for the m52/54) is not aluminium, but an alloy that is far stronger than aluminium which is a very soft metal. And the main thing that causes warps and craps are differential expansion - two different metals connected to each other firmly, expanding at different rates and thus creating a fissure at their joint. The likelihood of this is lower when the block and head are made of the same material. And my M50 have survived numerous overheats without lasting issue.
    Expansion of the metal under heat - this expansion is not huge, because the temperature increase is not substantial when compared to the melting point of the metal concerned.
    Anyway this is an academic argument. Once your gauge crosses 3/4 you need to give yourself a good reason why you shouldn't pull over. And if you can't then pull over and check under the hood. But you don't need to break out in a cold sweat even if it hits red - that's my point. But it is exceedingly irritating.
  8. #33
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    OK, here is my experience. The car is my DD, has AC, and was in Dallas and now in Austin, so dealing with a pretty good heat load / AC load + aux fan / traffic and low air flow. I do not have an oil cooler or a vented hood (yet).
    My aux fan started failing and blowing fuses, so I replaced it.
    The new fan had smaller connector pins than the original, so it would lose its connection sometimes. Maybe a lot, but I'd only notice it under certain conditions. Because my mechanical fan clutch was dead and it took me years to realize - the aux fan was picking up the slack.
    I finally put all the pieces together, fixed the pins on the aux fan, installed a Mishimoto radiator, and replaced the mechanical fan with a 17" fully caged Derale fan that I interfaced with the factory shroud and wired into the low temp wire of the the aux fan switch (this switch is the only piece of this whole equation that is still original).
    Others have commented on the difference between the fan switch and the vehicle's temp sensor.
    These are my OBSERVED temps for various conditions using an OBD bluetooth transmitter and the Torque app (i.e. temps come from the Torque app).
    The needle hits 12 o'clock around 170-175 degrees F, and starts moving north again about 225 F.
    I forget where the upper line is - I want to say 250, and the red starts at 265, but I've only ever seen the upper line in my own car once, and have never gotten to the red.
    But these numbers would be in line with the boiling point of 50/50 water/coolant at 16-20 psi, which is when you catastrophically lose cooling capability, so it makes sense the OEM would put those marks there.
    As for the aux fan switch.
    Low comes on around 208 degrees. You'll never see high with your hood up and the low speed functioning (even without any other fan running), so I don't have a recorded number for the high speed fan.
    I will also note that my fan (and I think most fans) run on low speed with one wire hot, and run on high with two wires hot. Meaning, you wire the low speed to the low temp switch and the high speed to the high temp switch. The low temp switch remains hot when the high speed switch closes. If you don't have two switches and want your fan to run at high speed, you wire both together into the one switch for high.
    Being in Texas, I don't see any need to ever run just at the low speed, so I wired both together for high speed to come on from the low speed aux switch.
    So the Aux fan comes on at low speed when it hits 208 or when the AC is on. It ramps to high when it gets to whatever the high temp is.
    My primary electric fan comes on at high when it hits 208 or when the AC is on.
    Even at crazy high ambient in the summer (120 or so), my car will run as low as 190 degrees sitting in traffic with the AC on. It can get up to 220 at sustained high speeds in 120+ weather, but will drop quickly to 200 or lower when I get off the highway.
    And being wired into the AC, my fans almost never come on from temperature. If it's cool enough to NOT need the AC, it's cool enough the car never gets up to 208 just from sitting in traffic.
    OP, if you still live in Dallas, you need to wire your fan into the low speed switch.
    The problem with using the high speed switch is that you're already above the boiling point of un-pressurized coolant. The more time you spend in the higher temperatures, the more time you spend with higher pressure in your system, causing fatigue, and the more opportunity for failures.
    And the faster a failure spirals out of control.
    This is why things go catastrophic. To address the conversation just above here, a healthy cooling system can handle up to around 265-275 depending on coolant mix and radiator cap (50/50 mix at 20 psi won't boil until 275, discounting any localized hot spots). With an old / unhealthy system, you're rolling the dice above 225. Any single component (a hose, fitting, plastic radiator neck, expansion tank) can be the failure point and get you in hot water quickly - even if most everything else is new.
    Once the needle starts moving (passing 225+), if you were to lose pressure your coolant is already above its boiling point. Pressure loss results in the coolant immediately boiling. So the coolant in the engine becomes steam, which means the only thing cooling your engine at that point is the oil. And that's why the temperature jumps up so quickly at that point.
    If it was me (and it was), I'd start as low as possible and keep it as low as possible.
  9. #34
    Oct 2012
    Detroit, MI
    E36, E70, i3
    Thank you
  10. #35
    Long Island, NY
    1995 M3 - 2007 X5
    Quote Originally Posted by zohaibrose View Post
    I have recently purchased an SPAL electric fan kit from online and it came with the SPAL relay kit and the fan, I have mounted the fan up to the radiator and followed the diagram to the relay.
    It says the yellow goes to the jumper positive terminal along with the fuse, the orange goes to pin 16 of the 20 pin round connector under the hood (green wire with white stripe) and the red goes to the pigtail harness of the fan and the black goes to ground, as for the grey wire I tapped it into the black and gray wire of the aux fan switch which I believe is the high temp.
    I allowed the car to idle and reach 208f but the fan never kicked on. I am confused why, I followed the diagram correct so I’m not sure. The 30a fuse is also receiving 12v so did I mess up something. Just note po deleted the aux fan so not sure if that has to do with something. I just wanted one main fan in front of the radiator to cool everything down since my ac doesent work anyway.
    Reference blckstrm's response for thoroughly explaining what to do in your situation. Your wiring is a little off, redo and test to check function as you should be wired to the low speed not the high speed. If nothing changes and the fan isn't kicking on then it could simply be a defective part from the manufacturer.
    Also, I would recommend putting the electric Spal fan behind the radiator as a puller-style not a pusher. You can retain the factory fan shroud which is helpful.
  11. #36
    Jun 2005
    New England
    For about 20 years, I have been using Evans coolant and zero pressure or lower pressure caps in some of my cars. I like the idea of less stress on the heater core, which is a pain to change. It has pros and cons and is not for everyone. Boiling point is much higher than even 50/50 water antifreeze and a 29 psi cap. Supporting mods probably a good idea — wider core radiator like z3 s54 m or mishimoto version or zionsville plus heavy duty pump like Stewart.
  12. #37
    Jul 2011
    Austin, TX
    Also, you should have wired a fuse in line somewhere. My fan is getting old and blew the fuse today (I may have a replacement in my near future). Make sure you check that fuse before going crazy.
    But yeah, it won't be turning at 208 if it's on the high temp. But that's an easy, easy fix to switch it to the low temp wire.
  13. #38
    Nov 2016
    texas
    1998 328is
    Quote Originally Posted by blckstrm View Post
    ye I’m still in Dallas area, will you come back to the area or are staying Austin, wanted to see your build.
    I did Add 30a Fuse, gonna switch it to the green and black wire(low temp switch) and if that doesent work, will have to get the 318i switch. But I will have to test all this after I can get the e36 started cuz now it won’t even fire up, fuel pressure is good at 51psi, gonna check for spark later, bad thing is there no crank sensor code so kinda stumped, oh well gonna try getting it back on the road
  14. #39
    Jul 2011
    Austin, TX
    I'll be at the big SCCA race at COTA tomorrow if you have the day free and want to watch the races. But yeah, I don't make it up to Dallas hardly at all anymore, and even when I do it's with the family in the Escalade, not in the M3.
    I was going to say you're safe for a couple days without a fan - it's almost cold this weekend. Did the wiring issues run the battery down?
  15. #40
    Jan 2016
    Ca
    2001 525it
    The oem system was simple and worked
  16. #41
    Mar 2013
    So~Cal
    2003 E46 M3 / E30 Vert
    Idk why there is so much problems with the electric fans. Buy the right stuff and do it once. I'm using the mishi fan, + mishi temp controller /relay. Literally no splicing, all plug and play. Turns on at temp set on controller, turns off below, no physical switch nonsense.
  17. #42
    Long Island, NY
    1995 M3 - 2007 X5
    Quote Originally Posted by Thrifty S50 View Post
    Its not an issue with the fan itself, OP wired it incorrectly the first time.
  18. #43
    Jul 2011
    Austin, TX
    Quote Originally Posted by ChuckDizzle View Post
    He actually wired it fine - he just wired it to the high temp switch for some reason. And then expected it to come on at the low temp.
  19. #44
    Nov 2016
    texas
    1998 328is
    well i wired to the low temp n still not come on at 208f , i even attatched a ring terminal to the grey wire and tried grounding it but the fan didnt come on with key in position 1. someone here said if you ground that grey wire from the spal relay n the fan doesent spin then your wiring is incorrect,
    but i dont get it, i have 12v to the wire going to battery jumper terminal, hooked up orange wire to pin 16 of diagnostic port, red is hooked up to the fan harness, and grey was tapped into the green n black wire. i can get the fan to be on constant if i remove the relay and apply power and ground to it but the relay seems to not work. i even tried removing the orange wire to see if the fan would turn on constantly without igniton but still no go, thinking my relay no good. darn i really need the engine to be kept cool or i will be stuck with a scrap engine. WHAT DO I DO
  20. #45
    Jun 2005
    New England
    Recheck your wiring. Make sure the relay powers the fan when the relay is triggered, by testing the trigger— the wire that taps into the temperature sender. It supplies a ground that turns the relay on. There is only a ground when the wax in the sender melts and allows contact between the wire in and the wire out. For the test, forget about that. Just run a lead off the relay ground, which is 85 or 86, depending on how you wired (one is switched relay power — key on #2 — if you want switched fan operation or unswitched if you want the fan to run with the ignition off, and the other is relay ground but these two terminals can be swapped without affecting relay operation). These two wires are small gauge like 14-18 since they pass little current.9
    30 is heavy gauge power in and 87 (not 87a) is heavy gauge power out to the fan. The fan ground is to the car chassis.
    Beware of using bmw colored relays. Many are not wired internally like Bosch standard relays. Unless you know how they work, use a relay with 85, 86, 87 and 30 terminals. It’s ok if there is an 87a in the middle but don’t use 87a.
  21. #46
    Jan 2016
    Ca
    2001 525it
    Wouldn't it be great to just have the stock system working perfectly, life could be so easy
  22. #47
    Jun 2005
    New England
    For most people, stock is easiest and more than adequate. However, none of my 3 cars are stock. I enjoy them much more in modified form.
  23. #48
    Jul 2011
    Austin, TX
    Quote Originally Posted by jclausen View Post
    Lots of people have less trouble - and less risk - with an electric fan. Not to mention freeing up a couple ponies...
  24. #49
    Nov 2016
    texas
    1998 328is
    Quote Originally Posted by ed323i View Post
    Not sure about the rest of the wiring (don't know the specs), but if you use the original stock aux fan switch in the radiator, and then use the high-speed (high temp) wire, then your fan will only start to run when the temperature is way, way too high, in or almost in the red on the temp gauge in the instrument panel..
    So, I would advise to get the lower temp rated aux fan switch (80 deg C low speed trigger, 88 deg C high speed trigger), and then first connect it to the low speed connection.. Then you'll be sure it should trigger at a healthy temperature. (in my E36, it triggers the low-speed aux fan at 80C and the high speed at 88C and that works perfectly fine with the stock thermostat@92C).
    I was gonna ask is how will the 318 style fan switch work for 328/m3 models? I see the pins on the switch for the 318 are a lot bigger then the 328 stock fan switch so do you have to switch harness too or what
  25. #50
    Jun 2005
    New England
    I salvaged a fan motor harness end and spliced it in. Fits perfectly. At least I think that is the connector I salvaged that fits. This was over 5 years ago.
  1. M42 electric fan conversion options
    By M42 Technik in forum 1991 - 1999 (E36)
    Last Post: 10-15-2016, 08:34 PM
  2. Electric Fan Conversion
    By Mr Project in forum 1988 - 1996 (E34)
    Last Post: 07-08-2012, 04:08 PM
  3. Replies: 28
    Last Post: 11-02-2007, 02:16 AM
  4. For those who've done the electric fan conversion
    By chancebanning in forum 1991 - 1999 (E36)
    Last Post: 01-30-2007, 12:40 PM
  5. electric fan conversion questions
    By coloROBo2002 in forum 2002
    Last Post: 07-21-2005, 11:58 PM
