Results 1 to 6 of 6
Thread: I Need Help with an E60 Expert
    Jan 2019
    Sulaimaniyah
    2005 BMW E60
    Hello Experts!
    I have 3 questions,
    I have a 2005 BMW E60 (530i), full option.
    1. I want to know does my car actually have Bluetooth? If yes, how to connect it with my phone. If not, is there anyway to do it?
    2. I am getting SOS error message, how can I disable it? Or fix it?
    3. How to remove restraint rear right & left error messages?
    I highly appreciate your time guys!
    Jul 2018
    Northern California
    2004 BMW 525I
    I have same question about an 04 525i when I check vin it says I have that along with voice control yet I can't seem to figure out either.
    Jun 2008
    Halifax, Nova Scotia, Can
    2004 E60 545i
    On the first item BT needs to be enabled thru coding likely, if not visible on the screen to turn on. Get either INPA/NCSEXPER Suite for laptop or the smartphone app to do it.
    https://www.mycarly.com/product/bmw-app/
    on the rest best to get/read and post your faultcodes to see what is going on.
    ">'85 Mlite E30, '98 E36, 1998 528i, 5 spd manual, black on black, sold in 2012 and still going past 350Kkms, now MYSTIC Blue 2004 545i, 6 spd Steptr., Adaptive steering and Xenons, Anti dazzle mirrors. Aux+Belt-Chime+Dig speedo+iDrive discl. 2007 TCU+BT Coded+Sure BT Board
    Jan 2016
    Ca
    2001 525it
    Sos might be able to be by passed with the optical loop. Your car was probably prepped for blue tooth but you need the module and program it in., chec you vin for phone prep option. You won't be able to remove the restraint messages until you find out why there on I believe
    Ft Lauderdale and CT, USA
    '07 530i and '07 328xit
    My first E60 was an early model where the SOS button had a stupidly bright light on it. Remove the switch/light assembly, cover the inside with tape, and re assemble it. It is otherwise useless at this point, anyway.
    Dec 2018
    Durham
    2008 E61
    Are you trying to connect to the phone for calling or streaming? you need to do a CIC/Combox retrofit to get bluetooth streaming.
    i would run your cars VIN through a BMW decoder to see exactly what options it actually has.
    the SOS error could be that your telematics unit(TCU) has failed. you may need to get a new one.
    the restraint errors would need to be fixed to get rid of the errors. getting the codes read would be a good start to figure out exactly what is causing the error. was the car involved in a wreck? could be that the restraints were replaced, but the vehicle was not coded to know that they were replaced.
    G~
  1. Need Help buying an E60 M5
    By marwan in forum 2004-2010 (E60,E61)
    Last Post: 07-31-2005, 07:33 PM
  2. need help from the paint experts here....
    By svb in forum Car Detailing and Show & Shine Prep sponsored by Autogeek.net
    Last Post: 09-18-2004, 11:48 AM
  3. i need help from u bmw experts
    By zombiebaby in forum 1983 - 1991 (E30)
    Last Post: 04-04-2004, 05:26 AM
  4. Need help from the photoshop experts
    By RDM3 in forum Off-Topic
    Last Post: 04-24-2003, 05:14 PM
