Just read an interesting classified post where the reader was describing the condition of his '02 Z3 M coupe and how well kept the vehicle had been. He used a term that I'm not familiar with saying he just had it black stone oil analyzed. Could someone please explain to me what this term is and the cost? TIA
I assume they were referencing this... https://www.blackstone-labs.com/?ses...m0b45%29%29%2F
My mechanic recommended that I send one in. Blackstone has a very comprehensive database on their end. They are able to tell the condition of your oil after it has been ran for a certain number of miles (they will recommend a sample mileage.) They have information on all different types of motors for all vehicles. Nice to have information like that.
... and if you send them samples for every oil change they will keep a running analysis going and will warn you if something starts to change. Highly recommended.
Marty
I thought this was primarily a S-54 issue due to rod bearing issues.
The ad you referenced was an S54 Coupe ........
Marty
I might add that I had analysis done for the last 60K miles on my car, then decided to change the bearings anyway when I hit 100K. My bearings were in excellent shape, and I could have left them in, so not all S54's have a problem.
Wasn’t my reference. OP shows a m54 in his profile.
Well another reason to be a member of this forum. I went to the web site another member directed me to, and found out that a free, yes free kit is available, the sample tested I think was around $28 and change. Would the members that had this done recommend this business as being pretty accurate??
Oil analysis has been an industry standard since before my career started__and I'm retired.
Unless particularly bad, a single oil analysis is not of much use; the goal is to develop a trend from samples taken over time, and as Marty says, will alert the operator of an impending problem before it becomes catastrophic. The maintenance departments keep a running tally on every piece of equipment that uses (any type) a lubrication oil and often times, does analysis for the coolants too. The minimal costs for the tests are nothing compared to equipment downtime and replacement (loss of production can exceed = $,$$$,$$$.$$).
Use in the private sector didn't begin until the 1980s (I've been doing all of my cars since 1985) and didn't really gain traction until the 2000s, coinciding with message boards and like-minded enthusiasts.
Whether you own an S54 or not, I maintain that tracking oil analysis is a good idea, and cannot help but to lend confidence to a buyer when you present the records should you ever be foolish enough to sell your car...
