Results 1 to 6 of 6
Thread: Noise from 210mm Diff
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    I have a 210mm 3.15 LSD in my e36 m3.
    About a year ago I snapped an axle shaft at the drag strip and (stupidly) limped the car 50 miles home on one axle shaft.
    Ever since , when taking sharp low speed turns my rear diff makes a cyclical grinding sound. It has progressively gotten worse. Additionally, during cruising the diff whines. I would like to pull it apart and fix it. Does this sound like pinion bearing and carrier bearings going out? Or clutches? Or both? Anyone have any resources for specs and all that good stuff for the 210mm diff?
    Thanks!
    Vancouver, B.C., Canada
    '97 M3
    Sounds like itís totally junk. Pull it and ship it to me, Iíll dispose of it for you.
    Nov 2013
    VA
    trbo 96 328;98 m3
    same thing happened to me late last year. Tried to show off with a burnout and ended up breaking one of my non m axles. Ever since, I have been hearing a clunk during shifts and the diff whines like hell during cruise speed.
    96 328 Turbo
    98 M3/4/5
    Mar 2013
    Upstate NY
    M3
    Damnit Raji, that was a mint diff I let you have and you be breaking it!!!!!! Shameeee on youuu.
    Feb 2012
    1995 BMW M3
    Quote Originally Posted by Mklock View Post
    I know But im trying to fix it
    Dec 2007
    SF bay area
    1998 M3 / 2000 S2000
    Quote Originally Posted by rajicase View Post
    Thanks!
    Iím assuming the unit was a 20+ year old used unit that was installed as-is mystery condition then ran so hard a cv died then limped home?
    In extreme cases of this (yes Iíve done it myself-) the differential housing itself can get damaged and pinion bearings take a shit from the strange 1 wheel drive load+ damage that caused 1wheel drive.
    Iíd anticipate some interesting wear on the internal components of the lsd also but itís not that crazy.
    Realistically- if it makes a noise itís dying and time to rebuild; probably was dying anyway as 20+ year old junkyard units are just that.
    If the unit was properly built and lsd optimized you could break an axel, drive home 1wheel drive change axels and continue on the warpath of abuse.
    Some new upcoming original Bay Area designed and Bay Area manufactured parts are in the works to avoid Europe and Japan entirely
    188 zf standard plates
    Upgraded more plates Internal set for 210mm os giken; os doesnít sell rebuild parts; only does service in house.
    Billet Original CNC LSD for 188K
    http://www.wanganstyle.com/
    S54B32 E36 M3 DTA S100 Sedan Street car full swap:
    http://forums.bimmerforums.com/forum....php?t=1437471
    E30 M20 2,7L Alpina + Euro E46 320D ZF 6 speed install
    http://www.e30tech.com/forum/showthread.php?t=110010
  1. Tire noise, bearing or diff ??
    By amancuso in forum 1999 - 2006 (E46)
    Last Post: 08-12-2008, 06:07 PM
  2. Humming noise from the diff.
    By rex567 in forum 1991 - 1999 (E36)
    Last Post: 11-19-2007, 10:45 PM
  3. Whil driving I think im hearing noise from the diff?
    By Garrett M in forum 1992 - 1999 M3 (E36)
    Last Post: 10-02-2007, 04:01 PM
  4. Whinning noise from tranny/diff on auto? Please say it isn't so.
    By tcmarley in forum 1992 - 1999 M3 (E36)
    Last Post: 12-29-2005, 03:51 AM
  5. Anyone encountered a humming noise from there diff?
    By Raff in forum 1983 - 1991 (E30)
    Last Post: 07-22-2005, 03:13 AM
