Hi everyone.
I own a BMW Z3 2.2i from 2002 (European model) and fixed various issues over the past 3 years using INPA.
Recently I came across ISTA-D and comparing that program to a printed screenshot from the dealership that printed me an overview of some active errors at the time before I got a diagnostics tool myself seemed very similar.
So I decided to install ISTA-D for myself on my own laptop.
First I had some trouble getting it running on Windows 7 (x86), presumably .NET framework related.
So I installed Windows 10 and ISTA-D pretty much worked out of the box.
Anyway, I decided to do a full-scan on my car and ISTA-D showed me a nice overview of my car's modules.
There were some errors active which I decided to clear, but to my surprise there were also quite some modules that ISTA-D marked as "ECU not responding".
Looking at those specific modules (IR, GM and BC_0xCD), it doesn't seem like they are really "broken" as I don't seem have any issues related to those modules (they seem to work just fine).
I also notice that there aren't a lot of modules compared to various screenshots and videos of ISTA-D I saw online. Is this always the case with E36 based cars?
As the car is relatively old, I can imagine that there aren't a lot of modules in these type of cars.
Do you guys (or gals) think the red modules really have communication issues in my car or if ISTA-D just marks them as false-positives?
Here are some screenshots of ISTA-D:
PS: I'm currently using Windows 10 Pro x86 with a K+DCAN USB cable using OBD.
Thanks!
Make sure your cable latency is set to 1ms or 2ms in Device Manager.
-Abel
- 2000 Z3: Many Mods.
- 1999 S52 Estoril M Coupe
- 2016 Mini Cooper S
Thanks for your reply. I've checked and I do have the cable latency set to 1ms:
Bump. No-one?
Did you have any joy with this? I have the same issue with my 2011 E70 X5.
Sent from my ONEPLUS A6003 using Tapatalk
It would definitely seem to be a laptop/software issue or cable maybe as Carly via a Bluetooth dongle seems to work fine. I know Carly is less comprehensive but doesn't seem to have a problem communicating with the ECUs.
Your 2011 X5 is completely different in every possible way in terms of diagnostics than the E36 mentioned in first post.
-Abel
Yes i know, but as the issue appears to be with ISTA-D and not the car itself I was just curious if the OP had found a config issue or anything that might help.
If you're using a K+DCAN, i would first make sure that your latency is 1ms in device manager. Windows default is 16ms and often misses modules.
-Abel
I had a non-communication with a my immobilizer module in my E36/7 but my car worked fine which makes sense based on how it works (it doesn't use the diagnostic line to communicate with the DME). I found that it had a broken wire that was a pain in the butt to track down.
I have the EXACT same problem with my Z3. Even the same modules that are not responding. Did you or anyone find a cause? I checked all my cables with a multimeter but almost out of ideas. Do we have the same (bad) cable?
