I have for sale most of the bits for a MK60 ABS swap. I had this running in my Supra, but decided to go with a different setup.
Comes with:
- 06 M3 module/pump
- both pressure sensors
- yaw sensor + bracket
- 4 rear E46 M3 sensors
- mostly-complete wiring harness with bulkhead connector (missing a abs sensor connector)
The wiring harness will likely need some work to be converted to whatever your setup is if you don't want the bulkhead connector, but I have the pin-out if you want to keep using it.
$500 + shipping for all of it.
What system did you switch over to, if you don’t mind my asking?
Sending this to a few ppl
What vehicle were you intending this to go into?
Sent a PM
Christopher
STX 197
1997 328is
Is this still available? PM Sent
If u have this stuff I’d like to talk..
Regards,
Trevor p
