Results 1 to 3 of 3
Thread: M20B20 Motronic 1.3 Conversion
    Jan 2019
    Brisbane
    1987 325e
    What parts are needed to convert a Jetronic M20B20 (320i e30) to Motronic 1.3. I know the ecu and engine harness is needed but I can’t find anywhere what other parts would be needed. The engine has been swapped into a 1987 325e so the car was originally running on motronic (I think).
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    moved to E30 forum
    Dec 2005
    corpus christi, texas
    No e30s, again :(
    I would imagine all the stuff for just a normal e to I swap. engine, engine harness, ecu, afm, injectors, and probably have to do some little jumpers in the cabin at the c104 like for the e to I swap. I was googling the other day because we did an e to I swap and I had found someone went through the same swap you are doing a number of years ago and I think they were told just act like its an e to I swap and wire that way
    No e30s again.
  1. Motronic 1.3 conversion ECU placement ideas
    By cfisher535is in forum 1978 - 1987 (E23)
    Last Post: 09-10-2016, 12:17 AM
  2. Motronic 1.3 Conversion Questions
    By YK91 in forum 1976 - 1989 (E24)
    Last Post: 05-26-2011, 03:12 PM
  3. 3.5 L-Jetronic to Motronic conversion
    By Bentsdl in forum 1976 - 1989 (E24)
    Last Post: 11-03-2010, 10:21 PM
  4. Motronic Conversion
    By Dogbox in forum 1975 - 1983 (E21)
    Last Post: 02-12-2008, 01:11 AM
  5. conversion 728i l-jet to motronic
    By alejandro728i in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 09-19-2006, 02:05 PM
