Results 1 to 6 of 6
Thread: 98 M3 Axle Interchangability
    Apr 2008
    Long Island ,NY
    95 M3 , 99 Z3 Coupe sold
    Good afternoon all ,
    My question is I removed both rear axles form my 98M3 Coupe to replace Hubs and bearings, and in the process I damaged the boots on one axle ( they were split partially ) and the threads on another ..If you have ever removed original axles you will understand....
    I have 2 good axles from a Z3 M Roadster, They are the same on both ends but are 1/4 in shorter when compressed as compared to the original M3 axles I removed.
    My car is on coil overs and stiff springs as its mainly my Track day car....
    Can the Z3M axles be used in my M3 coupe??
    I feel the shorter axle will only be an issue in excessive droop of the axle, and as I have coil overs the droop will be way less than a standard suspension setup....
    Thoughts
    I'm an Aussie living in the States , love it
    Modestly dyslexic so for give the spelling.
    Nov 2010
    Whidbey Island, WA
    1998 Techno M3 Coupe
    Sorry, I do not know the answer but would you tell me what wheels are you sporting in the attached picture?
    Thanks!
    Apr 2008
    Long Island ,NY
    They are Vosergen 17 x 9 with brand new Federal 525 in 235 40 17 all round square set up and they are for sale actually $1000.....
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Unfortunately, I don't have the answer to your question, but what you're saying makes it sound like it should work.
    Long Island? I don't think I've seen you around. FYI Autocross is starting up soon (three different clubs this year). Let me know if you're interested and I'll get you more info.
    Apr 2008
    Long Island ,NY
    Thanks always interested in seat time....
    Apr 2008
    Long Island ,NY
    Ok I ended up going with a set of replacement M3 ales even though the Z3M coupe ones fit I just wasnt sure about the 1/4 inch shorter lenght of the axles..Thanks for the input.
    Barry
  1. 98 m3 AXLES BOTH
    By LT 325is in forum Drivetrain & Transmission Parts
    Last Post: 03-04-2014, 02:11 PM
  2. Replies: 13
    Last Post: 09-08-2010, 01:05 AM
  3. 98 m3 subframe, trailing arms, axles
    By phily in forum Suspensions, Springs & Shocks
    Last Post: 03-20-2010, 09:11 PM
  4. MINT CONDITION '98 M3 Halfshaft/Axle (output shaft) ***38mm***
    By cooljess76 in forum Drivetrain & Transmission Parts
    Last Post: 05-25-2009, 09:15 PM
  5. Wheels interchangeable between 98 M roadster and 98 M3?
    By nvmym3 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 04-28-2004, 12:35 PM
