Results 1 to 6 of 6
Thread: Manual transmission shift detent pin bushing repair
    Oct 2007
    Bolton, MA
    2001 740iL, 2001 325Ci
    Hi all,
    My '01 325Ci has been a bit difficult to shift into Reverse or 5th gear. The more I read, I learn about "manual transmission shift detent pin/bushings that get worn or stuck and no longer function properly. Has anyone here swapped one or both ...or any of these?
    From the videos I'm seeing it looks like you have to pull the transmission, which if that's the case - I'll be bringing the car to my mechanic. Just curious if there's enough real estate in under there to swap these pins/bushings without pulling the tranny?
    Here's more details: https://www.bavauto.com/bmw-transmis...ng-23117542726 and https://www.bavauto.com/bmw-transmis...re-23311224849
    Thank you,
    Jay
    '01 325Ci Convertible, 5-speed
    '01 740iL, Stahlblau with beige interior & 18" M-Pars, GROM bluetooth
    '03 X5 3.0 six cyl, Gray on gray
    Oct 2003
    Seattle
    99 M3
    Ya, 5th gear ‘lean’ in an ZF S5D 320Z is a real issue, resolved by replacing the shift detent sleeves/pins.
    No room in the tunnel for the tools.
    https://www.google.com/shopping/prod...Y3VBtIQgjYI1gM
    Jul 2011
    Portland, OR
    M4, E36, E92
    Adding another question... I bought a ZF320 to swap into my 325 track car and was experiencing the famous 5th gear lean. I went ahead and replaced the sleeve bushing and put everything back together, replaced the fluid but I still have the 5th gear lean. I haven't ran the car yet because I'm doing other repairs. Will this go away once I run the car and everything gets lubbed up with the fluid?
    Being a track car, I'm a little worried since we live within the 3-4-5 gear range.
    Any ideas?
    Oct 2003
    Seattle
    99 M3
    Jul 2011
    Portland, OR
    M4, E36, E92
    Odenton, MD
    1997 BMW M3 Sedan
    Quote Originally Posted by jamanta View Post
    You need to do everything in the full kit to fully restore it. It makes a huge difference. Another good upgrade is the UUC DSSR.
  1. E36 Transmission shift detent bushing drift set
    By HotDoggin in forum Drivetrain & Transmission Parts
    Last Post: 03-22-2021, 09:40 AM
  2. Transmission shift detent pin question..
    By kt3130 in forum 1992 - 1999 M3 (E36)
    Last Post: 11-26-2013, 07:01 PM
  3. Another ZF Manual Transmission Shift Pin Service Tools Group Buy
    By Mark185 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-29-2010, 02:38 PM
  4. Another ZF Manual Transmission Shift Pin Service Tools Group Buy
    By Mark185 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 08-27-2010, 03:48 PM
  5. 1998 M3 cold manual transmission shifting issue ?
    By rcw in forum 1992 - 1999 M3 (E36)
    Last Post: 04-21-2010, 10:52 PM
