Results 1 to 2 of 2
Thread: 2005 BMW X3 E83 Blows hot and cold air
    Jan 2019
    Palm Springs
    2005 BMW X3
    Exclamation 2005 BMW X3 E83 Blows hot and cold air
    It used to just blow hot air but then I took it to get the A/C recharged. Now when have the Dial to Blue (coldest) and the temperature setting to the lowest, the Dash Vents blow ice cold. Once the car warms up, The Windshield and feet vents blow hot! As if I would have the heater on.
    If I select the button to direct the air through the dash vents only, it blends it and blows mildly cold air.
    The Heater works just fine. What could be causing this issue?
    Thank you!
    May 2003
    Toronto, Ontario, Canada
    '97 328i Cabrio
    The design of the heating and AC system in these cars is that under normal operation there will always be "cooler" air blowing at your face when the dial is set in the middle.
    If you set the dial more towards the blue it will get colder and the opposite will be true for the red blowing warmer air.
    When you leave the system on the auto setting it will blend and adjust the air flow as it sees fit and can blow hot air from the middle at times, but generally there will always be cooler air from the middle vents.
  1. Replies: 1
    Last Post: 08-31-2016, 05:58 PM
  2. 2005 BMW X3 Wouldnt Start After Cold Weather
    By tommymulligan in forum 2003+ X3, X4 (E83, F25, F26, F97, F98, G02)
    Last Post: 03-28-2016, 09:26 PM
  3. Problem to install Yatour YT-M06 BMW BM2 40 pin on BMW X3 E83 3.0D M57N 2005
    By nasca in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 03-19-2016, 12:49 PM
  4. Blowing Hot and Cold Air
    By chad94 in forum 1999 - 2006 (E46)
    Last Post: 10-20-2014, 10:20 AM
  5. Air conditioner blows hot and cold air
    By innovator54 in forum 1999 - 2006 (E46)
    Last Post: 07-23-2010, 12:05 PM
