Results 1 to 15 of 15
Thread: M50, M52, M54 cam adjustment blocks
    Apr 2006
    Minnesota eh?
    86 325es
    If your on facebook you've probably seen these already but I've started producing these 3D printed cam timing blocks.
    works on all M42, M50, M52, S50, S52, M54 engines.
    Works just like the factory timing blocks but have built in angle for 0-15 degrees of advance or retard. They snap onto the back of the cams and will not fall off. They are reversible, one side advances the cam, flip it around to retard the cam.
    The non vanos blocks are for installing a non vanos intake cam into the exhaust side of the head for a cheap upgrade over M50 cams.
    Pricing
    $25 each (minimum of 2)
    $120 your choice of 6
    $150 full set of 10
    Free shipping on everything. For international orders I will do my best to do free shipping or to keep it as cheap as possible. I should be able to do free on most international orders.
    If you want a different color or a custom angle please send me a message, that is no problem. Anything from 0-40 degrees will be easy to make.
    86 325es, 2.8L m50, S472sxe, MS3pro Ultimate, e85, solid rear axle, 4 link, spool, TH400 trans, Protorque converter, 28x10.5w slicks, zip ties
    Best = 9.43 @ 149.15 mph, 1.30 60 foot 28 psi boost
    Vancouver, B.C., Canada
    '97 M3
    What about the indicator style.
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by chikinhed View Post
    I can make one of the dial adjustable ones if you want but it doesn't fit on an E36 due to the firewall.
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    These are so cool.
    Question though, and forgive my ignorance.. What is the best way of determining what is best for a given set up? Is there an easier way than doing this on the dyno and making pulls after each adjustment?
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by rajicase View Post
    These are so cool.
    An educated guess could be made depending on the setup and what cams are being run. Chickenhed shared some data from his experiments and I've done some playing with mine as well. If someone has a stanalone you can also see the changes reflected in the VE table.
    '97 M3
    These would be great for my retorquing of the 11 mm head studs in my near future.
    Jul 2005
    PEI, Canada
    2001 330i
    Very cool Perry.
    I'm going to get a few from you to play with the M54.
    The way to VANOS is setup on the M54, these would be great to put the cam in a non-standard position.
    On the exhaust side, the cam is wildly biased for what I think is emissions....because it doesn't make any sense to me what the range of adjustment is in the WRONG direction. (Hurts VE when you move the exhaust cam with VANOS) On closer evaluation, I found that my exhaust lobe position is nearly 20 degrees off from what works on other boost FI BMWs....
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by PEI330Ci View Post
    Very cool Perry.
    Just curious, what cam angles did you find to work well on your car at different RPM's?
    Just let me know what you need, if you need a different angle than what I have made I can draw it up.
    Virginia
    97' m52 turbo
    @vollosso
    What set should I get for my car?
    m52/ s52 Cams
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by 328iFun View Post
    @vollosso
    m52/ s52 Cams
    Itís going to be very related to back pressure.
    I would get a set of lower angles and play with the exhaust cam and look for spool changes.
    1989 535i - sold
    1999 Tiag/Dove M3 - sold
    1998 Turbo Arctic/black - current
    2004 TiAg/Black - Current
    PTE6870 | 1.15 ar | Hp Cover, Custom Divided T4 bottom-mount, 3.5" SS exhaust, Dual Turbosmart Compgates, Turbosmart Raceport BOV, 3.5" Treadstone Intercooler, 3.5" Vibrant resonator and muffler, Arp 2k Headstuds | Arp 2k Main studs | 87mm Je pistons | Eagle rods | 9.2:1 static compression, Ces 87mm cutring, Custom solid rear subframe bushings, Akg 85d diff bushings, 4 clutch 3.15 diff, , Poly engine mounts, UUC trans mounts W/ enforcers, 22RPD OBD2 Stock ECU id1700 E85 tune, 22RPD Big power Transmission swap w/ GS6-53
    Jul 2005
    PEI, Canada
    2001 330i
    I figured I would explain why the wacky cam timing works for anyone new to moving the timing around.
    The aim when trying to increase boost is that each cylinder filling event has more volume (mass) than the previous event. To do this, you want to increase valve overlap at TDC to maximize the amount of fresh charge volume vs burned charge volume in the cylinder. The key to this is that the inlet port pressure is higher than the exhaust port pressure. As the mass flow through the exhaust increases, the back pressure increases, and eventually you end up with a 1 to 1 ratio with the inlet charge. The engine wants completely different valve timing for the inlet biased pressure, vs equal pressure, vs exhaust biased pressure.
    When the engine has equal pressure seen at TDC in the exhaust and inlet ports, it behaves like a naturally aspirated engine.
    When the inlet pressure is higher than exhaust pressure at TDC, it behaves like a bigger engine.
    When the exhaust pressure is higher than inlet pressure at TDC, it behaves like a smaller engine.
    By moving the exhaust timing around, you are trying to "hide" the high pressure from when the inlet valve is open. (In addition to aiding in cylinder blow-down) If you have a "big" cam though, there will be a point where you loose engine power because the exhaust is open too soon, AND the inlet is seeing some exhaust pressure at TDC. This is where you would move the inlet valve timing away from being open at the same time as the exhaust valve, which hurts top end power (The inlet likes to be open earlier at higher RPM) but helps with midrange spool and torque production.
    And here are some variations on this strategy:
    Due to a mistake in how I interpreted my exhaust VANOS position, you can see with the Turbo M54 exhaust centreline that I was mirroring the shape of the S54 turbo centreline, but the cam off by a LOT. This is where I'm looking to move my exhaust cam splines by 30 degrees to get it lined up with the Turbo S54 exhaust centreline. BTW....I ran that exhaust timing curve (Blue) for a very short time before I locked the exhaust position at -103 Degrees. (The VE took a dive on data logs)
    Apr 2006
    Minnesota eh?
    86 325es
    Your 2nd picture doesn't work
    Feb 2018
    Bulgaria
    e92 335i; e36 m50b28
    HI, i want to place an order. How to do it.
    Apr 2006
    Minnesota eh?
    86 325es
    Quote Originally Posted by gixercho View Post
    I sent you a private message.
    Mar 2016
    Australia
    e30 318i, 135i
    id like to order a set, international order please.
  1. K&N Panel Filter for M50, M52, M54 engines.
    By TomPeters in forum Engines, Performance Parts & Software
    Last Post: 01-10-2011, 02:19 PM
  2. Differenece bet. M50, M52, M54 Shape? How to know?
    By The Buccaneer in forum General BMW sponsored by Intercity Lines
    Last Post: 05-18-2010, 01:09 PM
  3. FS: ARP Head Stud Kit BNIB E36 M3 S50 S52 M50 M52 M54
    By WK446 in forum Race Cars & Track Parts
    Last Post: 03-14-2007, 08:19 PM
  4. Arp Head Studs Bmw 3 Series M3 E36 M50 M52 M54 158.00
    By Turbo ///M50 in forum Forced Induction
    Last Post: 02-15-2007, 09:30 PM
  5. New M50/M52/M54 E36 & E46 323i/325i/328i/330i/M3 Replacement Water Pump
    By vehdyn in forum BMW Parts For Sale sponsored by Bavarian Auto Recycling
    Last Post: 11-12-2006, 07:41 PM
