Type of maintenance |
Milege |
Date |
Type of Repair |
Milege |
Date |
Oil change/ Engine Filter |
109000 |
5/1/2013 |
CHEAP Radiator. Upper hose. Expansion tank. Rear ball joints. |
109000 |
05/01/13 |
Coolant Flush- BMW Coolant |
109000 |
5/1/2013 |
Thermostat, Alternator |
110000 |
06/14/13 |
Trans& diff oil, brake fluid |
120000 |
1/14/2014 |
All front control arms and thrust arms, 2 outer tie rods, |
115000 |
09/14/13 |
Fuel filter, spark plugs |
120000 |
1/14/2014 |
Sway bar links+ bushings for the sway bar |
115000 |
09/14/13 |
Oil change |
120000 |
1/14/2014 |
Clutch slave cylinder, CDV removal |
125000 |
01/01/14 |
130000 |
7/5/2014 |
OBD Cluster pixel repair |
125000 |
04/01/14 |
Cabin Filters |
133000 |
labor day |
Seat belt buckle with pretentioner |
130000 |
07/10/14 |
Oil change |
139000 |
1/5/2015 |
Side markers housings+bulbs |
131000 |
07/18/14 |
4x Hankook V12 Ventus Evo2- new |
145000 |
6/5/2015 |
Cabin Filter Housing cover |
131000 |
07/18/14 |
Wipers x2 |
144000 |
5/15/2015 |
Cabin Filter Air Ducts |
133000 |
laborday |
Oil Change |
148000 |
8/10/2015 |
ZHP shift knob |
130000 |
Oil Change |
155000 |
10/15/2015 |
Behr radiator, upper hose, lower hose, expansion tank+hoses |
135000 |
09/12/14 |
Engine Air Filter |
155000 |
10/15/2015 |
Rear sway bar links, hood release cables x3 |
135000 |
09/12/14 |
New Continental Extreme Winter Contact Mounted Ballanced and Installed |
157000 |
11/14/2015 |
New BMW Battery |
139000 |
12/12/14 |
Re-mounted 4x Hankook V12 Ventus Evo2 |
161000 |
3/19/2016 |
Shocks and struts, springs+mounts&bearings/ Rear Control arms and trailing armsX2 |
140000 |
01/19/15 |
Oil Change |
162000 |
4/7/2016 |
All 4 brakes- rotors, pads and sensors |
140000 |
01/19/15 |
Oil Change |
167700 |
8/1/2016 |
All 4 speakers replaced with Boston and Hybrid audio+ original Alpine retrofit. |
142000 |
03/20/15 |
Oil Change |
169000 |
10/10/2016 |
All 4 summer wheels refurbished- straightned and repainted |
145000 |
06/04/15 |
Hankooks replaced by winter tires due to serious puncture- may be could have lasted another 5k |
171500 |
11/8/2016 |
All interior lights chaged to LED |
147000 |
07/08/15 |
Driver side wiper raplaced |
171500 |
11/8/2016 |
Front left low beam ballast replaced |
147000 |
07/08/15 |
Oil Change |
175000 |
12/28/2016 |
California rear left door- color match and shadow trim |
147000 |
07/08/15 |
4 new Continental Extreme contact DW- installed and mounted |
177172 |
2/17/2017 |
Door panel corners insulated for better speaker performance |
148000 |
08/01/15 |
Engine Air filter, Cabin Air Filter, P/S reservoir cap new O-ring |
177200 |
2/21/2017 |
BC Stalk replaced |
149000 |
08/20/15 |
Oil Change |
181125 |
3/7/2017 |
Engine RPM corrected |
149000 |
08/20/15 |
2 front Continentals replaced due to flat spots/ nail repaired-rear passanger |
182000 |
4/6/2017 |
Rogue Engineering Thrust Arm Bushings- street performace |
150000 |
09/30/15 |
Engine Air Filter/ 2 Windshield wipers |
189000 |
10/7/2017 |
Camshaft positioning sensors x2-updated ones |
152000 |
09/21/15 |
Oil change |
189000 |
10/14/2017 |
2 new front forward wheel well covers |
152000 |
09/21/15 |
Re-Mounted winter tires, reballanced |
189500 |
11/10/2017 |
Engine rpm corrected again |
152000 |
09/21/15 |
Spark Plugs, Oil change(due to VANOS failure), Trans Oil |
190000 |
1/20/2018 |
TRW sway bar links x2-did not help with low speed knocking. Old ones seem to be OK. |
155000 |
10/18/15 |
Cabin Filters |
191000 |
2/10/2018 |
Clutch kit/ Brass pivot point/ Pivot spring/ New nuts and bolts for exhaust |
157000 |
11/18/15 |
Engine Air Filter |
191000 |
2/10/2018 |
Trans mounts/ Rear main Seal/ Rear Coolant Cover/ Shifter Shaft Seal/ Coolant flush |
157000 |
11/18/15 |
Windshiel wipers- VALEO |
191000 |
2/10/2018 |
2x After Cat O2 Sensors |
158000 |
01/08/16 |
Oil Change |
192222 |
2/13/2018 |
A/C Belt & Serpertine Belt |
166000 |
6/28/2016 |
Brake Flush |
192222 |
2/13/2018 |
Rear left Side window blind self repair with EP-200 epoxy putty |
168000 |
9/2/2016 |
Re-mounted Continental DW |
193415 |
5/25/2018 |
Timing V guide, Tensioner Rail, Guide Rail, Cam tensioner rail, Oil separatorx2 |
169000 |
9/27/2016 |
Oil, Oil Filter, Coolant |
Oil Change |
199158 |
1/15/2018 |
Cooland Valley gasket, T. Case cover gasket, Seal Strips, Upper Oil pan, Lower oil pan |
169000 |
9/27/2016 |
Remounted winter tires |
199000 |
1/5/2018 |
Valve cover gasket, VANOS solenoid seals, Front and rear Cover seals, Fr. Crank seal |
169000 |
9/27/2016 |
Rear left reverse light bulb |
199158 |
1/15/2018 |
Water Pump-metal impellar, Termostat, Cross pipe O rings, Alternator seal, Rear cover, |
169000 |
9/28/2016 |
Heater engine hoses, Intake seal, Pulleys, engine mounts, P/S suction hose, |
169000 |
9/28/2016 |
Secondary Air pump mounts |
169000 |
9/28/2016 |
Drag link, outer tie rods, P/S return hose, VCG again due to slow leak again, |
172000 |
12/5/2016 |
radiator nipple, alignment,right-front undercover, MAF replaced- check engine, rich mixture. |
Oil Level Sensor cleaned due to intermittent "low oil level" message. 01/16/17- no message |
175000 |
12/28/2016 |
Brake pedal switch replaced- did not help with DSC/Brake/ ABS warning lights |
181000 |
3/7/2017 |
Checked airbag due to Takata recall and dealer refusing to replace due to non- original airbag |
181500 |
3/24/2017 |
turns out previous owner raplaced airbag with EURO spec NON Takata airbag- AUTOLIFT |
DSC/ABS module replaced. Front, driver side, outer PDC sensor raplaced |
181500 |
3/24/2017 |
New Nissens radiator, Expansion tank, new gas filler cap |
183333 |
5/24/2017 |
VANOS repair, New V guide and tentioners, New shifter and bushings, Timing Chain |
190000 |
1/20/2018 |
Rear end rubber brake lines |
192222 |
2/13/2018 |
Vanos solenoid, bank 1 passenger side |
196000 |
8/13/2018 |
2 front brake shields |
8/14/2018 |
Camshaft positioning sensor BANK1 |
196000 |
28/08/2018 |
