Results 1 to 5 of 5
Thread: New BMW guy here, need advice-info on M52tub28. Rebuild-able or must replace?
    Jan 2019
    Farmington, MO, USA
    2000 528i Sport Wagon
    Have recently agreed to purchase a 2000 528i wagon that's gotten hot. Guy says engine is 'toast'. Car has 140k and is very clean. Understand that engine is '99 and '00 only. Is it rebuild-able after coolant system failure? Head destroyed? I've not found a replacement engine as of yet. Thanks for any help/advice.
    SF Bay Area, CA
    BMWs: 1; MINIs: 1
    My old race car had that engine (‘99 Z3 2.8 Coupe). I damaged the radiator in a wreck once and managed to overheat it. Blew the head gasket. While I was at it, I put a rebuilt head on there and it ran great from then on.
    So anecdotally, an overheated M52tu doesn’t always destroy the bottom end when overheated.
    I like the unicorns.
    '99 Z3 Coupe - Jet Black/Black (1-of-114)
    '99 M Coupe - Estoril Blue/Black (1-of-82)
    '03 540iT - Sterling Gray/Black (1-of-24)
    '16 Z4 sDrive35i - Estoril Blue/Walnut (1-of-8)
    Jun 2013
    Boston, MA
    99 528i/5, 05 ZHP conv
    I have had several of the '99 - '00 M52TUB28. They're good engines, and if it wasn't for the throttle body problems, I would think it is the best of the BMW 6 cyl engines, though there will forever be disagreements on this.
    You can certainly rebuild your engine, and I have done a head gasket with engine in car, but I would look to replace that engine, which is easier and most often cheaper. Rebuild your orig engine on a stand afterwards if you want to..
    - you can remove the engine and transmission as a complete assembly without taking the front off.
    - take radiator out, put hood in vertical "service" position, unbolt AC compressor and PS pump and strap them to sides
    - unplug wiring harness at DME and lay it on top of engine. Remove exhaust at down-pipe and pull manifold with engine
    - use an engine hoist with a load balancer (a must)
    - then freshen up replacement engine and re-attach transmission and re-install
    - replace engine mounts if they are original or show any sign of leakage
    M52TUB28 engines are getting harder to find, but you can still get them from a dismantler. or find a parts car 5-series, 3-series, Z3 with that engine, do a compression test, and use that as your engine source.
    Also - I have gone thru about 6 M54 and M52TU engines that have overheated. About 60% of the time, the head has warped so much that it is uneconomic to have a machine shop resurface it and put it back in service. Also, you would want to time-sert the 14 head bolt threads in the block before re-installing the head.
    Spartanburg, SC
    85 M635, 98 Z3, 00 528iT
    Quote Originally Posted by effduration View Post
    - ...put hood in vertical "service" position,...
    How do you do this? I could do it with my old W124 Mercedes and loved that ability.
    Thanks,
    Eric
    Jun 2013
    Boston, MA
    Study the hood hinges first.
    Then unhook hood struts and move hood to near vertical.
    Insert an appropriately-sized bolt thru hole in hinge (sideways) to lock it in place
  1. New guy here needs advice.
    By HodgyNFFC in forum 2006 - 2012 (E90, E91, E92, E93)
    Last Post: 08-12-2014, 04:50 PM
  2. new guy here needing advice
    By Topauf in forum General BMW and Automotive Discussion sponsored by Intercity Lines
    Last Post: 08-13-2013, 07:22 PM
  3. new BMW owner soon need Info
    By MarineBimer in forum 1999 - 2006 (E46)
    Last Post: 11-25-2011, 12:12 AM
  4. New guy and need some info!!!!!!!!!!!!!
    By boannski in forum 1983 - 1991 (E30)
    Last Post: 05-16-2009, 02:45 AM
  5. Time to get new rims and tires...need advice.
    By g2go1818 in forum Tire & Wheel Forum sponsored by The Tire Rack
    Last Post: 09-17-2002, 12:47 AM
