Do anyone know where can I find a Valve Body rebuild kit for a 4HP24 transmission? My car, 1992 850i.
Hurt
Current project working on the E31 rebuild.
1992 BMW 850i, 1995 E31 840ci, 2008 E90 M3, 2008 750Li
There is no kit like for the 5HP30. The 4HP24 parts you have to buy as single parts based on the parts list number and serial number on the ZF sticker on the trans.
If you contact a shop like Eriksson with these details they might be able to select the necessary items, they can then print out from the ZF catalog the detailed parts list based on the serial number and the parts list number = Stucklistennummer.
Basically you need some new plastic balls, a new plate gasket, in rare cases maybe a spring, solenoids can be cleaned and polished. A dealer will of course offer you much more, just to be sure that nothing is missing.
Paper gasket for the 4HP24 I always use 1043 328 080, that is the latest version.
For 4HP22 there are even more different gasket versions based on parts lists
1043 326 161 4HP22
1043 326 162 4HP22
1043 326 232 4HP22
1043 326 253 4HP22
5HP30 based on built year
1055 327 093 5HP30 old version
1055 327 102 5HP30 new version
new version can replace old version but NOT vice versa, the 5HP30 will not work!
This is for example the 5HP30 VBK https://zftranspart.pinnaclecart.com...t_version=true
27.020 1056 327 019 Orifice 1.0mm 1 All 5HP30 part numbers
27.030 1056 327 039 Orifice 1.7mm 1 All 5HP30 part numbers
27.034 1056 327 021 Orifice 1.5mm 1 017/026/027/028/029/ 030/031/032/039/040 316 Valve body & over
27.040 1056 327 020 Orifice 1.2mm 1 All 5HP30 part numbers
27.050 1056 327 019 Orifice 1.0mm 1 All 5HP30 part numbers
27.060 1056 327 020 Orifice 1.2mm 1 All 5HP30 part numbers
27.070 1056 327 020 Orifice 1.2mm 1 All 5HP30 part numbers
27.086 1043 326 037 Check Ball 1 All 5HP30 part numbers
27.090 0501 313 177 Filter Screen 1 All 5HP30 part numbers
27.096 0732 041 937 Compression Spring 1 All 5HP30 part numbers Valve in channel plate
27.100 1055 327 093 Gasket 1 010/011 312 Valve body and under
27.100 1055 327 102 Gasket 1 017/026/027/028/029/ 030/031/032/039/040 316 Valve body and over
27.260/116 0501 209 253 O.-Ring 2 All 5HP30 part numbers
50.020 1056 327 173 Selector Shift Valve 1 All 5HP30 part numbers
50.040 0732 042 430 Compression Spring 1 010/011/029/030/031
50.060 0732 042 477 Compression Spring 1 All 5HP30 part numbers
50.070 1058 327 030 Main Pressure Valve 1 All 5HP30 part numbers
50.080 0732 042 381 Compression Spring 1 All 5HP30 part numbers
50.110 0732 041 550 Compression Spring 1 010 309 Valve body and under
50.110 0732 042 492 Compression Spring 1 011/017/026/027/028/029/ 030/031/032/039/040 312 Valve body and over
50.128 0732 041 523 Compression Spring 1 All 5HP30 part numbers
50.142 0732 041 526 Compression Spring 1 All 5HP30 part numbers
50.148 0732 041 809 Compression Spring 1 All 5HP30 part numbers
50.158 0732 042 561 Compression Spring 1 All 5HP30 part numbers
50.170 0732 042 561 Compression Spring 1 All 5HP30 part numbers
50.190 0732 042 561 Compression Spring 1 All 5HP30 part numbers
50.204 0732 042 561 Compression Spring 1 All 5HP30 part numbers
51.030 0732 041 547 Compression Spring 1 All 5HP30 part numbers
51.060 0732 041 462 Compression Spring 1 All 5HP30 part numbers
51.080 0732 041 462 Compression Spring 1 All 5HP30 part numbers
51.100 0732 041 826 Compression Spring 1 All 5HP30 part numbers
51.120 0732 041 337 Compression Spring 1 All 5HP30 part numbers
51.140 0732 041 462 Compression Spring 1 All 5HP30 part numbers
51.190 0732 041 606 Compression Spring 1 All 5HP30 part numbers
51.210 0732 041 547 Compression Spring 1 All 5HP30 part numbers
51.260/010 0734 313 120 O.-Ring 1 All 5HP30 part numbers
51.270/010 0734 313 134 O.-Ring 4 All 5HP30 part numbers
55.030 0732 041 462 Compression Spring 1 All 5HP30 part numbers
55.050 0732 041 826 Compression Spring 1 010/011/029/030/031
55.070 0732 041 337 Compression Spring 1 All 5HP30 part numbers
55.090 0732 042 382 Compression Spring 1 All 5HP30 part numbers
55.110 0732 042 504 Compression Spring 1 All 5HP30 part numbers
55.130 0732 042 022 Compression Spring 1 All 5HP30 part numbers
55.150 0732 041 667 Compression Spring 1 All 5HP30 part numbers
55.170 0732 041 325 Compression Spring 1 All 5HP30 part numbers
55.180 1043 326 037 Check Ball 1 All 5HP30 part numbers
orifices are only needed if you lost one when disassembling, compression springs usually no need to replace, in abt. 10 years I have found 2 broken ones, selector shift valve can be re-used, but I have some on stock, mainly for 5HP18 and 5HP30, as they sometimes break. So such a VBK includes everything what could be necessary in worst case, but most things are not necessary. Such a VBK for the 5HP30 is also only available in the US, in Europe the shops change parts when needed.
Thank you!!!
Hurt
After you got your parts, please let us know for reference
Stuecklistennummer = parts list number of your 4HP24 trans
where you bought them
detailed list of the parts with ZF part numbers
That will help for future questions
