I was on the highway driving zigzagging car was moving then I let off the pedal when I went to give it power again it hesitated I let up then tried again it jerked and drive train malfunction came on I had the car towed I couldn’t put in in neutral so was dragged onto flatbed and shook off! It was late so I left it at the mechanic now he don’t know how to put it in neutral or what to do as far as diagnose sense car can’t be put in shop since it’s stuck in park! How do I put in neutral and does anyone know why this stuck gear box not allowing me to shift gears please share ASAP!!!!
car starts up but don’t shift gears at all
Codes that came up on OBD Scanner
400004
213901
CD9001
Also can it be low or empty transmission fluid and or mechatronic seal adapter/o ring shrink
I believe the 2009 model still has the neutral release below the cupholder. There should be a red T-shaped handle thing in the tool kit. Under the cup holder (pop off the cover), or turn the cover to get it off. If you have it, stick the T-handle in the square hole and turn. Voila! Neutral. I'm sure you could google it, or find a YouTube video of the procedure.
Thank you for the Reply I was able to get I’m in Neutral from under the car I will check for the link under the cup holder tomorrow
Did you fix the problem my car is doing the same
My d light is flashing
