Results 1 to 4 of 4
Thread: Xenon-Headlights Problem ( Need Help ASAP)
    Jan 2019
    Dallas,Tx
    2005 325ci Coupe
    I am new member to this forum. I wonder if anyone can help me with a problem I am having with my 2005 325ci coupe. I just replace the Xenon-ballast, igniter and light bulb for the driver side headlight. The problem I am having is the light will not come on. If I unplug the passenger side light and then plug in the driver side the light will work. So when both lights are plug in they are working but when I turn the lights off for several minutes then turn them back on only the driver side come on. So what is my problem?
    Jan 2017
    USA
    E21, E46
    You will want to see if there are codes. If so reply back with what codes are present.
    Jan 2019
    Dallas,Tx
    2005 325ci Coupe
    Hello RobertDenali there is no code showing. So you think it a bad wire connector.
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    What did you scan, the engine computer? The module that needs to be scanned is the lighting control module (LKM).
  1. Depo Headlight Problem!!! NEED HELP ASAP!
    By jrhaile in forum BMW Rides & Events
    Last Post: 06-15-2006, 09:37 PM
  2. Really Big Problem Need Help ASAP!!!
    By rcr2880 in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 04-01-2004, 11:20 PM
  3. Electrical Problems! Need help ASAP!!
    By CJ in forum 1992 - 1999 M3 (E36)
    Last Post: 10-14-2003, 11:39 PM
  4. Guys, serious power steering problem, need help ASAP
    By M20 E30 in forum 1983 - 1991 (E30)
    Last Post: 05-20-2003, 09:01 PM
  5. Serious Coolant Problem - need help ASAP!!!!!
    By AaronM3 in forum 1992 - 1999 M3 (E36)
    Last Post: 12-17-2002, 12:45 PM
