RM European Auto Parts
Results 1 to 19 of 19
Thread: PCV Valve
    Jan 2019
    Sioux City, IA
    2002 BMW 325xi Touring
    CCV Valve
    Hey guys. New to the forum and new BMW owner. I have a 2002 325xi. Recently had an ordeal with what I believe to be a bad CCV valve. It has been negative degree temperatures where I live. Was running late one morning and didn’t let my car warm up properly. Pulling into work smoke was filling the cab and coming out from all over the engine. Oil seemed to be spewing all over the passenger side engine bay. I’ve done some research on the internet and have come to the conclusion that the PCV valve froze and basically cause my valve cover to blow. Is that correct? Oil was only on the passenger side of the engine bay so Thats was I assume it is since it slants down to the passenger side. Anyways. Purchased a new cold weather kit and upon replacing everything I noticed yellow sludge in all the breather tubes and dipstick tube. From what I’ve read this is from condensation? I’m sure somebody has had a run in with this. Anything else I should check into? How do I clear that system from sludge after replacing the tubes? Saw some in the openings to the intake manifold and vanos. I can post pictures. Probably left out some information. But I can give as needed. I appreciate it.
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Welcome to the Forum!
    Yes, allowing short trips in sub-freezing temps can cause the CCV valve to freeze. The fact that it froze shut is a good thing, for if it froze open, you would have a hydro locked motor on your hands. Please take a look at the attachment, as this is BMW's fix to the problem.
    Also be sure to replace the valve cover gasket too, and inspect the valve cover for cracks, ect.
    P.S. If you haven't had it done yet, call a dealership to see if the passenger side airbag has been replaced, or click here!
    P.P.S. As a "while you are in there" attach a vacuum line to the CCV to reduce oil consumption too.
    Attached Files Attached Files
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    New York
    1974 2002, 2009 128i
    I suggest you read this: https://www.bimmerforums.com/forum/s...CV-replacement
    While you're not chasing the same problem I was, the mod eventually described in the link above will also benefit your engine. A byproduct of if it is that it increases crankcase vacuum considerably, which evacuates moisture more effectively, and thus dramatically reduces the formation of the oil-water emulsion you describe.
    Life's tough. It's tougher when you're stupid.
    -John Wayne
    dworthy's Avatar
    Nov 2010
    Quote Originally Posted by 02Pilot View Post
    Yeah, I had thought about pointing him towards your thread, just couldn't find it at the time.
    Darin
    Current:
    Past:
    M-Flight Member
    Jan 2019
    Sioux City, IA
    Thanks for the help guys. I didn't even think about replacing the dipstick guide tube. Probably very important, haha. Couldn't find the info on it but what would be a good way to achieve getting rid of the sludge out of the openings to the intake manifold and the valve cover? Is there a flush? Or do you just try to wipe it as best as possible?
    P.S. I was testing how the connectors work for those tubes and ended up breaking the ring around the outside due to it being a tad cold in my garage. Will it still clamp or do I have to get a new one?
    Attachment 644399
    dworthy's Avatar
    Nov 2010
    Well the kit comes with all hoses needed to completely replace the CCV and pipes. The dipstick tube is a redesigned part, as it removes the inner liner, and allows it do drop it directly in.
    Yes, you can tape that hose back into place for the time being, and my favorite place to order OE parts: www.thebmwminipartstore.com As an added bonus they are also forum sponsors, all you need to do is get the part numbers from my PDF and put them in there.
    Darin
    Current:
    Past:
    M-Flight Member
    Jan 2019
    Sioux City, IA
    Makes sense. I might as well get the dipstick tube while I’m at it. And I apologize if I didn’t quite grasp what you said, but will I have to order another hose for the one that I broke? I’ve never dealt with these connectors before.
    New York
    Ideally you'd get another hose, as once those clamps break they don't really hold properly. Taping it up will work (in theory), but it's also asking for a vacuum leak long-term. Spray a little WD-40 on the O-rings on those hoses - they will go together a lot easier. Cleaning the emulsion out of the valve cover nipple and other areas is best accomplished with a simple zip tie - just drag the worst of it out so air can flow; the rest will dissipate in due time, assuming you do the mod to increase vacuum.
    -John Wayne
    Jan 2019
    Sioux City, IA
    Perfect. Thank you very much for the information.
    dworthy's Avatar
    Nov 2010
    Just so you know this is everything that comes in the kit:
    https://www.realoem.com/bmw/enUS/sho...diagId=11_2194
    Be sure to order #6 as our engine age they like to drink oil, and that is the vacuum hose I refer to. Your car will not have it, as BMW didn't install it for some odd reason.
    Darin
    Current:
    Past:
    M-Flight Member
    Middle of a corn field
    E39 hamster/ruberbandPWR
    It's capped on the M54.
    M52tu has a hose to the fuel pressure regulator, I believe...
    Jan 2019
    Sioux City, IA
    https://www.ecstuning.com/b-genuine-...e/11617533400/
    This is the one that I ordered. It’s sitting in my buddy’s garage, so I can’t verify for sure at the moment. Not looking like it has the capped nipple that the standard one provides.
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    It's underneath all the padding. The cold weather version is the same, except with a bunch of fluff.
    Chris Powell
    BMWCCA 274412
    Jan 2019
    Sioux City, IA
    I finally got everything buttoned up. The only one that I struggled with was the one that connects to the valve cover. I heard it click in on both ends, but when I connected it to the valve cover on the top end it seemed to have pulled out a little bit. Unfortunately there's no room to move it in any farther when I got the OS screwed down. Do you think it will be alright?
    Jan 2019
    Sioux City, IA
    It's not going anywhere, but I'm thinking about dabbing some RTVon there just for safe measure. Thoughts?
    dworthy's Avatar
    Nov 2010
    Those connectors are not designed to have anything else added to them. What I like to do on the O-rings is add a touch of oil or lube to make it slide in easier.
    Darin
    Current:
    Past:
    M-Flight Member
    Jul 2011
    Arlington, VA
    2018 BMW M240i
    Getting rid of the crud under the valve cover requires more frequent oil changes, and weekly highway speeds+ runs of at least 20 miles. As for the intake, clean what you can with a rag. Lastly, check the DISA valve o-ring. The embedded o-ring can leak.
    Jan 2019
    Sioux City, IA
    Right. Just with the trouble I’m having I was just wondering. It mainly has to do with the casing around it. But I shaved most of it down in my trouble spots. But like I said, once I mount it, it seems to pull just a little bit. Must have to do with the cold. I did indeed lubricate the o-rings though. Almost seems like that’s what’s making it want to slide back out.
    dworthy's Avatar
    Nov 2010
    There will be a little bit of play, and yes the cold can be "shrinking" some of the rubber. The fun one is attaching the 90 degree turn to the CCV, that one always gives me problems.
    Darin
    Current:
    Past:
    M-Flight Member
  1. PCV Valve Noise
    By danp412 in forum 1992 - 1999 M3 (E36)
    Last Post: 01-17-2006, 09:28 PM
  2. PCV valve on an M52?
    By fredo328 in forum 1991 - 1999 (E36)
    Last Post: 01-03-2005, 08:59 PM
  3. Where is the PCV valve on a 318 (M42)?
    By ClubSportCohort in forum 1991 - 1999 (E36)
    Last Post: 09-15-2004, 07:55 PM
  4. how do you modify the pcv valve?
    By BMuu in forum 1992 - 1999 M3 (E36)
    Last Post: 04-01-2004, 12:23 PM
  5. PCV Valve
    By psk145 in forum 1991 - 1999 (E36)
    Last Post: 11-14-2001, 02:00 AM
