Results 1 to 7 of 7
Thread: Transmission Question Before I Replace it
    Sep 2010
    Augusta, GA
    92 850, 95 840, E90 M3
    Question Transmission Question Before I Replace it
    I purchased my 1992 850 Auto about a year ago. I am slowly working on it getting it road worthy again. Since purchase, I have only put about 10 test miles on the car. The reverse worked and now it is not working. I replaced the filter and fluid. Do you think a valve body rebuild would fix do anything or just replace the transmission? I called a company that rebuilds ZF valve bodies and he didn't think that the valve body had anything to do it not going into reverse. The car was sitting for a few years before I purchased it. Thanks in advance for any help.
    Hurt
    Current project working on the E31 rebuild.
    1992 BMW 850i, 1995 E31 840ci, 2008 E90 M3, 2008 750Li
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    Yes, that does sound like the check-ball problem in the valve body, they are ceramic and gradually wear and reduces in size to a point where it gets stuck in an oil gallery. However, I would guess that the fella is just gummed up after all those years of sitting. It is certainly worth a try at getting the gearbox temperature up by driving and keep trying to get into reverse.....
    My BMW Repair YouTube Channel
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    In case the car sat for a few years, all is gummed up in the valve body, even the solenoids could be sticking. I would give it a try to clean the valve body, replace the balls, and for the 4HP24 you always need a new gasket between the valve body plates, that is baked onto the plates.
    If you would live in Japan, you could send me the valve body for overhaul.
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Cleaned mine out with Shogun's help. Did not fix the problem because the clutches and plates in mine are shot.
    A lot cheaper and easier than removing and replacing the transmission
    Jan 2005
    Japan
    Usually after you have removed the ATF pan, carefully inspect the bottom of the oil pan and the magnets, as well as the ATF. Does the ATF smell burnt, is dark? Bad sign. Are there larger particles on the magnets or in the oil pan like metal pieces 1-2 cm large: bad sign, in such a case it is better to change the trans. But there are always small particles inside from the clutch packs, that is normal, like dust.
    Some pics how it looks usually inside the valve body of a 4HP24 http://e32b12.blogspot.com/search/label/4HP24
    Sep 2010
    Augusta, GA
    Thanks, There was only dust particles and didn't have any large pieces. I am trying to find a valve body rebuild kit. Any suggestions?
    Quote Originally Posted by shogun View Post
    Hurt
    Jan 2005
    Japan
    call Eriksson if they have stock or if you can send yours there https://zftranspart.pinnaclecart.com//
  1. 2011, 2012 528i xDrive transmission question before i buy
    By James925 in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-14-2013, 10:50 AM
  2. Transmission questions - replacement required?
    By Black88GTA in forum 8 Series (E31)
    Last Post: 09-30-2010, 11:28 PM
  3. Lower Chain Tensioner - dumb question before I replace
    By Moron95M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 08-16-2009, 01:54 PM
  4. Last question before Headgasket replacement
    By Anders22 in forum 1991 - 1999 (E36)
    Last Post: 06-24-2009, 11:39 PM
  5. E32 Engine Replacement and Transmission questions
    By mullenc525 in forum 1988 - 1994 (E32)
    Last Post: 10-22-2007, 11:34 PM
