Results 1 to 4 of 4
Thread: Looking into Restoring My E46 Coupe
    Dec 2018
    Baton Rouge
    2001 BMW 330CI
    Hello,
    I have been looking at other cars. The new BMW 200 coupe is nice but I can't afford it, 52k. The 2019 3 series drives like a sedan ( can't afford it either). I drove the 2006 version of my car, but it was an automatic so I didn't like it.
    Since I like my car so much, I'm thinking about restoring my E46 Coupe. It's the 3 L 2001. I thinking I might change the color to red. I will put in a new IC, tail lights, AC, suspension components. My is primary that is get repaired so I can use it as a primary car again. Then performance, fix it so it performs well, then pretty. Make it look nice.
    Any suggestions would be appreciated.
    May 2012
    Central Wisconsin
    '94 325i, '93 325is
    What issues does it have now? Rust and cosmetic issues or mechanical problems?
    Dec 2018
    Baton Rouge
    2001 BMW 330CI
    There's a little bit of rust on the driver A pillar. The IC needs to be replaced. There is an oil leak by the oil filter. Ac needs to be replaced, tail lights need to be replaced, probably a break job, passenger seat won't tilt - probably a stripped gear. Also the suspension parts need to be replaced.
    I have already done a lot. New transmission, belts, blower motor, coolant system between radiator and engine (replaced some pipes), tires.
    Dec 2018
    Baton Rouge
    2001 BMW 330CI
    Ok a lot of important stuff already done, e.g new transmission, water pump, coolant system. Remaining issues,
    Air filter, Cabin Filter, VC gasket, thrust breaks, sway end links, Update p/s pump, IC cluster, radio amp. Some rust on the driver A pillar, tail lights, passenger seat won't adjust. Motor ok, won't move.
  1. Looking for pictures of e46 coupe with style 193m's
    By train80 in forum BMW Rides & Events
    Last Post: 09-15-2010, 12:40 AM
  2. New and looking at getting a e46 coupe
    By Astrabritz in forum 1999 - 2006 (E46)
    Last Post: 04-30-2010, 11:55 AM
  3. Looking to get a E46 Coupe but had a couple questions
    By r0c5t4r in forum 1999 - 2006 (E46)
    Last Post: 02-06-2007, 05:16 PM
  4. Need Help!!! Looking for E46 coupe front clip!!!
    By b0st0npiggy in forum 1999 - 2006 (E46)
    Last Post: 05-13-2006, 01:07 PM
  5. Looking for kidney grill for e46 coupe
    By natchris in forum BMW Parts For Sale
    Last Post: 08-17-2003, 07:17 PM
