Results 1 to 5 of 5
Thread: PO445 & 446 code on M Roadster
    Oct 2018
    Surfside, Fl
    1998 BMW Z3M Raodster
    Hello,
    My check engine light came on today. Connected code reader and came up with PO445 & PO446 fault codes. Looks like the fault is associated with the emission system of the car. Has anyone experienced the same faults on their roadster? If anyone can point me to how to go about correcting that issue would be greatly appreciated.
    **Interestingly, I was stopped at a traffic light (car in neutral) and I felt the rpm dip momentarily and that triggered the check engine light to come on. Otherwise, the car runs perfectly normal.
    As always, thanks to the community for being an invaluable resource!
    Jul 2004
    Houston, TX
    36 Cylinders
    https://www.fcpeuro.com/products/bmw...ve-13901744150
    This valve is likely shorting out. It is found around your intake manifold.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Oct 2018
    Surfside, Fl
    Thanks! Is this accessible under the hood or do I need to put the car on a lift to access?
    Oct 2018
    Surfside, Fl
    Just noticed that my fuel cap was not fully in closed position. Can that cause this issue?
    May 2015
    Maryland
    1998 M Roadster
    Yes
  1. Program / Code '06 M Roadster for Hardtop Option
    By Leftover Salmon in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 08-24-2015, 10:07 PM
  2. Need to Reset "Code Wait" in 2006 BMW Z4 Roadster
    By kramerico in forum Car Audio & Electronics sponsored by Bavsound
    Last Post: 06-27-2010, 03:06 PM
  3. M Roadster pulling codes
    By FNflyin90 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 10-20-2008, 10:24 AM
  4. 2006 M roadster paint code
    By Rocket88 in forum 2002 - 2008 Z4 (E85, E86)
    Last Post: 04-28-2008, 03:11 PM
  5. Fault Code Reader for 2001 S54 M Roadster
    By sab0276 in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 05-03-2007, 05:02 PM
