RM European Auto Parts
Results 1 to 5 of 5
Thread: Clutch Slave Cylinder Ran Dry
    Dec 2018
    San Diego
    2013 328i, 2002 330i
    While I was changing the clutch and flywheel I took the clutch slave cylinder off the transmission and accidentally let it run dry when I disconnected the line and now the clutch pedal just goes to the floor. There is still brake fluid in the master brake cylinder.
    I was going to pick up a nmeutatic bleeder to hopefully suck down the fluid from the master brake cylinder. Should this fix it? Or is there something else I need to do?
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Yes, that would be the easiest way to fix it. The clutch cylinder is self-bleeding, but takes a very long time to do so, and make sure you keep the fluid level close to MAX.
    The last time I self-bleed the clutch, it took about 1/2 hours of pedal pumping.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    I'm a simple soul. I gravity bleed the clutch. Of course, the slave has to be dismounted from the trans, and turned upside down with the bleed screw the highest point.
    My fellow tech, just this week, removing an engine and trans from an E46, disconnected the hydraulics to the slave....bled that sucker dry. (Not the way I do it, but he's a LandRover guy).)
    I told him that since we were already there, remove the CDV, then hydraulically reattach the slave, then flip it, fill the reservoir, and gravity bleed it.
    He did what I said, the clutch needed no further bleeding, and the clutch worked even better, with no CDV.
    Chris Powell
    BMWCCA 274412
    Dec 2018
    San Diego
    I've been bleeding this thing for a while now but the peddle is still hitting the floor. The fluid looks like its running clear
    Dec 2018
    San Diego
    Finally! I have a clutch again
  1. clutch slave cylinder?
    By ///M3 CRAZY in forum 1992 - 1999 M3 (E36)
    Last Post: 02-13-2004, 09:31 AM
  2. Has anyone replaced their clutch slave cylinder?
    By vinnymac in forum 1992 - 1999 M3 (E36)
    Last Post: 01-19-2004, 05:30 PM
  3. Clutch Slave Cylinder Help
    By CASTRO in forum 1991 - 1999 (E36)
    Last Post: 05-15-2003, 11:20 PM
  4. @#*%)#&*%$#@ clutch slave cylinder!
    By M3 Pete in forum 1992 - 1999 M3 (E36)
    Last Post: 03-27-2003, 01:06 PM
  5. clutch slave cylinder a "wear" item?
    By fast4d in forum 1992 - 1999 M3 (E36)
    Last Post: 08-12-2002, 04:40 PM
