RM European Auto Parts
Results 1 to 10 of 10
Thread: CAS: D904/not present - CAS K-CAN line fault
    Oct 2018
    Cyprus
    e88 118i
    Hi guys!
    i was investigating an OBDII error initially on my BMW e88 118i N43 engine UM12 type car after engine light going and coming. As the P2096 didnt mean much i replaced the pre catalytic O2 sensor but no luck, then got a foxwell NT510 bmw diagnostic tool. As a start i had reset all codes yesterday morning and by now, i got the below errors:
    CAS:
    DME:
    2EF7/not present - DME Map thermostat activation
    30C1/not present - DME Engine-oil pressure control, static
    2AF4/not present - DME Nitrogen-oxide sensor, electric
    2AF2/not present - DME Nitrogen-oxide sensor, lambda linear
    2AF6/not present - DME Nitrogen-oxide sensor, signal
    2C31/not present - Oxygen sensor emissions control
    So its 2x codes less compared to how it was before the reset, but maybe they’ll appear anyway after sometime probably.
    Would you say that there’s an issue with the Nox sensor? And what’s the K-CAN line fault? Could it it be a wire that causes the whole issue?
    looking forward for your opinion
    dworthy's Avatar
    Nov 2010
    Grafenwoehr, Germany
    16 220i 05 325it 05 M3
    Run down the bus and see if it is cut/rubbed/burnt somewhere.
    I think this is the correct wiring diagram for your car: https://www.newtis.info/tisv2/a/en/e...x15006/oKqRbTF
    As for the other DME codes, check your fuses first, then test each item using the website I supplied.
    Darin
    Current:
    Past:
    79 525 euro Green/Green RIP
    M-Flight Member
    Oct 2018
    Cyprus
    e88 118i
    Wow i didn’t even know about this website.
    But how did you end up suggesting looking at x15006-x15006 loop? I mean i understand that since the error has CAS in it would imply Car Access System but how would you know where to look?
    Sorry if my questions might be silly, but never did car electrical / electronics related works on a car.
    dworthy's Avatar
    Nov 2010
    Not silly by any means. Yes, check between the connectors to ensure you have a good wire running, you will need a multi-meter. Do a google search on "Continuity Testing" and that will tell you if the wires are okay. Next you will need to use an oscilloscope to look for signal, but for that I think you will need a shop.
    Darin
    Current:
    Past:
    M-Flight Member
    Mar 2003
    St. Joseph, Mo.
    95 m3+, 03 ZHP, Mk4 Tdi
    mate - i think the clue was in the trouble code description "CAS K-CAN line fault"
    that right there tells us there's some issue with one of the networks in the car. this is a network by which many of the modules in the car communicate.
    Jul 2004
    Houston, TX
    36 Cylinders
    Also, cas modules simply fail sometimes.
    -Abel
    - 2000 Z3: Many Mods.
    - 1999 S52 Estoril M Coupe
    - 2016 Mini Cooper S
    Oct 2018
    Cyprus
    e88 118i
    so gents, i have traced this to be the passenger occupancy sensor.
    lucky i got the part at a local shop, spent my whole Saturday on it,
    time to look at the other issues :/
    Jun 2002
    Aberdeen, NC (yes, again)
    E39M5, E500 4WD
    Yeah, um...the occupancy sensor isn't related to the codes above.
    Start by replacing the thermostat; that's a given.Likely you've got a bad NOx sensor, too. I'd be worried about that oil pressure code, as that one can kill the engine dead.
    Chris Powell
    BMWCCA 274412
    Oct 2018
    Cyprus
    e88 118i
    Well the occupancy sensor was the reason of the K-LINE error code (which i tought that it could have something to do with the other problems - for example issue with the bus down to DME/DTE). After replacing the sensor the K-LINE issue went away forever
    NOx sensor on its way!
    And i’m also worrying about the oil pressure warning mainly because i did hear rattling sound a few time during engine startup (reminded me a steam engined train) but inwas assured more than once by the mechanic that i shouldn’t pay attention as it only happens during warmup and it could be a pressurizer. Nevertheless i don’t enjoy the fact either that i had to buy a diagnostic tool and find out myself the the oil pressure and thermostat errors are almost permanent (they come back within minutes of erasing them)
    I’ll post an update once NOx sensor replaced. I’ll request an oil pressure test and a smoke test and take it from there
    Jun 2002
    E39M5, E500 4WD
    I'm very glad you've found and fixed your culprit, but I'd have to consider some part of the initial fault code for the K-CAN to be incorrect wording. After all, while the passenger seat occupancy sensor reports to the MRS (Multiple Restraint System), which is certainly on the K-can bus, that's really not a "line fault" on the K-can at the CAS. Ah well, all that matters is that you got a capable scanner, which pointed in the CORRECT direction.
    You should replace that thermostat. Be aware that an engine running hot, because of, say, a thermostat that's not opening on time, will produce more NOx. AND, perhaps cause the engine to overheat, costing a LOT of money.
    If you have ISTA, BMW's own diagnostic system, it can do guided test plans for your codes, which might lead you exactly to the cause of the oil pressure and NOx codes
    Chris Powell
    BMWCCA 274412
  1. About to swap; car will not pass CA BAR. Advice?
    By lokister1 in forum Engine Conversions
    Last Post: 01-07-2019, 12:04 PM
  2. Replies: 1
    Last Post: 04-01-2017, 10:39 PM
  3. Brand New CAS Keys Not Working?
    By jbh1989 in forum 2002 - 2008 (E65, E66)
    Last Post: 12-25-2011, 03:38 PM
  4. Fault code d6 - Vehicle speed singal not present
    By Zoso in forum 1992 - 1999 M3 (E36)
    Last Post: 10-19-2011, 06:22 PM
  5. Jim Conforti chip not shifting at NEW red line?
    By OregonAlpine in forum 1995 - 2001 (E38)
    Last Post: 06-26-2007, 11:47 AM
