So i have a 1998 740il that i plan to manual swap, this is what i have figured out.
540i 6 speed
15mm longer 540 shift linkage
88 mm longer driveshaft?
can i use the 540i pedal cluster? i dont care too much about the parking brake. i can figure out a mounting system later.
what master cylinder can i use and lines?
Just use the E38 pedal bracket. There is no reason to reinvent the wheel, or parking brake in this case.
you need a '97 e39 clutch master cylinder and use the e39 hydraulic line.
mc-21526758827
line-21521164429
Trevor
01 749i sporty, build 12/00 "Sports Barge",S62
92 VW Corrado VR6,AAA
81 Delorean,B28F
81 VW Rabbit Pickup 1.8T,AWW
03 VW Passat wagon 4.0 W8 6spd
