Results 1 to 25 of 46
Thread: Transmission Remove and Replace
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Getting ready to swap the ZF 4HP 24 transmission in the my 850 this upcoming weekend.
    Any great tips for getting to the top Bellhousing bolts?
    Other than a Long Extension?
    Sep 2008
    Santa Barbara
    91 Dinan860 & 91 850 6sp
    very long extension is the easiest.
    '91 850i 6sp (mint) (sold)
    Orlando, FL USA
    As Cartoonz stated, very long extension and some patience.
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Quote Originally Posted by ChrisFuture8 View Post
    some patience.
    Going to need it, not a lot of space
    Sep 2008
    Santa Barbara
    it helps to disconnect everything and drop the rear of the transmission down before trying to attack those bolts.
    You'll find the if you play around with where the different length extensions that you put together makes a bit of a difference on how easily you can line up the socket with the bolt heads too. Surprisingly, with the rear of the tranny lowered just a bit, you can reach the bolt heats with your fingers on one hand to guide the socket on.
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Quote Originally Posted by cartoonz View Post
    you can reach the bolt heads with your fingers on one hand to guide the socket on.
    I also have children with small hands that will be helping if needed.
    Every 12 YO girl needs to know how to pull a transmission.
    Feb 2016
    Brooklyn, NY
    1995 840Ci, 2013 X5
    If you remove the fan and unbolt the engine and guibo, you can tip it up quite a bit. Access to those top bolts would be much easier with an engine hoist. Or perhaps a jack under the front of the engine.
    I should explain a little further. I have an 840, so perhaps your experience will differ. I just put my engine/transmission as a unit back into my car after a long rebuild. As I was easing everything into position, I saw that with the engine on its mounts, the transmission tilted down as expected. But if I lifted the engine just enough to clear the mount bolts, the transmission tilted WAY down.
    Brett
    Sunny Cali,
    6.5 second 69 Camaro
    Be sure NOT and i mean Not! turn the engine the wrong direction when searching and lining up the Torque converter bolts.
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Clockwise and I am going to avoid the fan and shroud unless I need it.
    Sunny Cali,
    I would remove the fan, When you tilt the engine, I've seen it sometimes try and poke at the Radiator, Just keep your eye on it's distance when you lower the rear of the trans.
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Trans
    I pulled the fan, made it easier to get to bolt on crank to get the torque converter bolts out.
    There is a surprising amount of room with the trans tipped down. Not really that far.
    Had to pull out most of the insulation, it was rotted and in the way, it will be getting replaced.
    Got all of the bell housing bolts out but one on the mid left. Having problems getting extension on it. Might loosen the exhaust downpipe for additional clearance.
    I will get back to it
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Out
    Got it out, Had to rip out more Insulation was the problem, replaced with some Cool Mat, made sure to leave sunroof drain holes open, now on to replacing front Pump seal and rear seal just because it is easy now, Transmission was a Reman, car has 185K Miles, no idea how many miles were on this one
    Sunny Cali,
    Good job, I like it and it's the only post in the E31 section with pictures removing the 4HP24
    Sep 2010
    Augusta, GA
    92 850, 95 840, E90 M3
    +1
    Quote Originally Posted by 8eights View Post
    Hurt
    Current project working on the E31 rebuild.
    1992 BMW 850i, 1995 E31 840ci, 2008 E90 M3, 2008 750Li
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Here is is
    Drop the Rear of the Exhaust, support with Jack, Remove center mounts Pull out O2 Sensors
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Exhaust
    Unbolt the front and Drag it out, Helps to have a friend. Heat Shields are rusted, Replacements are available, I am going to wrap them with Exhaust wrap. Transmission Mount was Trashed from the Upper Oil Pan Gasket LeakIMG_20190112_101715.jpgIMG_20190112_101653.jpgIMG_20190112_112252.jpgIMG_20190112_123159.jpg
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    You have to remove the starter, Fan is optional, I needed to, Insulation was trashed and got in the way and was replaced with Cool Mat. You have to Disconnect Shifter, and Electronics cable on the other side. Get the torque converter bolts from the front thru the hole. Crank the motor clockwise to get to the next one. Two Bolts on the top of the bell housing are smaller Male Torx. I cracked them all off with a breaker bar and long extension and spun them out with an Air Ratchet
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Insulation
    Replaced all the insulation with Cool Mat, Leave the drains open on both sides, you can stick you finger in them.
    Cave Creek, AZ
    1993 850ci 2001 M5 / Z3M
    I like the insulation upgrade, seems like so many of these cars have pieces missing or insulation rubbing on driveline. The cool mat should provide more protection too and be thinner than factory
    Can you provide information on which cool mat used?
    Regards,
    Brian
    Cave Creek, AZ
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Thermo-Tec
    Quote Originally Posted by bdiefAZ View Post
    https://www.amazon.com/gp/product/B004PILLZG
    And some Metal Tape that you use for Ductwork to finish the seams
    Sep 2018
    Belgium
    1990 850i and 1970 2800C
    rjjablo, i see you removed at least 2 down pipes..... just out of curiosity , do they also have that overschoot material on the "cup joints " ?
    On my car i had 3 with overschoot to dia 36 mm and 1 which was butt welded and kept the pipe dia of 41 mm less some welding metal on the inside.
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Downpipes
    Quote Originally Posted by Belgiumbarry View Post
    Yes I have a significant Lip on mine. Approx 36MM, I was just eyeballing it with a tape measure, these are from the right hand side of a LHD Car US Spec
    Sep 2018
    Belgium
    the same…. yes, it is 36 mm , i measured it with a hole saw that just fit . Strange for a "down" tube of 41 mm. But as John said, they went to 500HP ( FI ) with those pipes…. i drilled them out but it shouldn't be a bottleneck after all.
    thanks !
    Oct 2016
    Shoreview MN
    Had a 1991 BMW 850
    Transmission is In
    Got the Transmission in today, Put Torque converter on and slide until it just slides in. Cannot get car high enough to clear both Trans Jack with Transmission on it. Slide it underneath, Jack up back of trans and put a 2X4 under front and jack it up until I could get trans jack underneath it. Wiggle and move and align, and loosen and move etc until it goes clunk and its together. Put in 4 bottom bolts, easy. 4 Top Bolts, Less easy but not difficult with long extension. Two for the starter, not hooked up yet so easy. Discover that the two on the opposite side of the starter had a nut on the block side that are lost since I spun them off with an air ratchet.
    Sep 2018
    Belgium
    i admire you guys without a lift..... i'm to old for working on the ground.
  1. Shop Hours to Remove and Replace a 4 HP 24 Transmission
    By rjjablo in forum 8 Series (E31)
    Last Post: 09-18-2018, 08:36 AM
  2. 2004 Bmw 530i automatic transmission removal and replacement
    By Andrew Maltby in forum 2004-2010 (E60,E61)
    Last Post: 09-26-2015, 05:13 PM
  3. Transmission removal & replacement?
    By logle in forum 1991 - 1999 (E36)
    Last Post: 07-06-2010, 10:58 AM
  4. Transmission removal, where to get engine brace
    By mrhmmhmm in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 09-06-2002, 12:21 AM
  5. Transmission and clutch replacing...
    By NoSoup4U in forum 1992 - 1999 M3 (E36)
    Last Post: 07-30-2002, 12:51 AM
