Results 1 to 25 of 55
Thread: Schapenwagen, The last chapter
    Mar 2012
    Renton, Wa
    98 m3
    I'm always complaining how BFC is dead so I'm doing my part... for the 10 of you that still read this board.
    You can find the previous couple chapters of my builds on here. All with the same car. I could find them for you guys but apparently all of google has stopped indexing old bimmerforums posts..
    In continuing style I'll list where I was at and what I'm doing now. I'm doing this in part to be able to remember.
    FUN MODS to date
    • 22RPD 6Speed Trans kit
    • Billet clutch with twin 1000tq disks
    • Stainless trans brace
    • Stainless dust shield
    • 22RPD stock dme 1700cc Tune
    • 22RPD Turbo Manifold
    • PTE 6870 Hp cover 1.15 t4 divided exhaust
    • 3.5" exhaust Vibrant Big resonator and muffler
    • 4" Inlet piping with R2c big cone filter
    • Tr1235 intercooler
    • 282/273 cams
    • 9:1 87mm Je/Eagle motor
    • Cutring
    • 10mm ARP HSK, s54 MSK
    • Fuel system
    • twin 485LPH pumps
    • Aeromotive Big regulator
    • 1/2" stainless hardlines
    • Russell Filter
    • CAE Shifter (Modified Greatly)
    • ATI Damper
    Boring Mods to date:
    • Aluminum 3 row Radiator
    • Tck Sa 300#/400#
    • Vorshlag plates/Radial bearings
    • Jtd RSM
    • Fikse fm10's 9.5" square
    • 245F 255R 40 r18
    • Rally Road Gauge pods
    • AEM Wideband Failsafe
    • AEM TruBoost
    • UUC Braided Clutch Line
    • UUC Enforcer Transmounts
    • REVshift Engine Mounts
    • Rally Road High Engine Mount
    • POLY Diff, RTABS, and Lollipops
    • Custom Aluminum sub frame bushings
    • M50 Manifold
    • Stewart Water Pump
    Mods going in this build
    • Twin 515's now with an auxiliary 485
    • Custom AC Condenser Lines
    • Tr1245 (4.5" intercooler)
    • 22RPD intercooler brackets (Soon to be released)
    • New motor
      • s52 crank
      • ARP Main studs (Standard Kit)
      • 1/2" ARP Head studs
      • Integrated Engineering Rods
      • Paul Pistons 8.8:1 3L
      • Stainless Oring Block W/ Elring HG
      • CES Extreme port head (Jimmy's Old Head)
        • Now clearanced for 1/2" studs
    We planned to do this guy over the long weekend.. as is the normal now no time for my own cars.. We started tearing the car down Friday and it would be back together today but our ARP Nuts are held up in Wyoming, so tomorrow it will be back together.
    Pictures to come!
    1989 535i - sold
    1999 M3 Tiag/Dove - sold
    Feb 2012
    Birmingham, Alabama, USA
    1995 BMW M3
    ]What will displacement and compression ratio be in new motor?
    Mar 2012
    Renton, Wa
    98 m3
    3l 9.2:1
    1989 535i - sold
    poconos pa
    e36 m3, turbo e36
    Looking forward to seeing some pictures. Do you have any good sound clips of your exhaust by chance?
    -sold...replaced by turbo e36
    Jun 2005
    New England
    F90 M5; E36 M3 Turbo
    What happened to the87mm bore motor?
    Mar 2012
    Renton, Wa
    98 m3
    We’re kind of in the middle of going through it.
    At this time we are of the belief that we lifted the head, hydro locked the cylinder which blew the cylinder walls out on both sides, then it looks like the piston grabbed the wall and stretched the rod in half. I’m talking with the component manufacturers now trying to work through it, I’ll post pictures eventually. Trying to drop this motor in tonight!
    1989 535i - sold
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by beeasy View Post
    The dyno videos from a while back should give you an idea of the sound
    1989 535i - sold
    Vancouver, BC Ca
    1993 325is
    Quote Originally Posted by vollosso View Post
    Curious to see these!! I might need a set.
    • Paul Pistons 9.2:1 3L
    Que?
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by jakermac View Post
    Que?
    New old stock Burke’s . I actually think they are 8.8:1 now that I'm not in the garage.
    The brackets will be nice stainless, 20 ga, CNC bent. With an AC line kit they will fit easily a 4.5" intercooler or without the ac line kit easily 3.5". Probably could push both of those 0.5" wider if you really got into the crash bar.
    1989 535i - sold
    Jul 2005
    PEI, Canada
    2001 330i
    Thank you for that.
    I enjoy reading your posts.
    Nov 2009
    Long Island, NY
    67mm 325i, RAM 1500
    This is good, excited tovsee what she does all turnt up.
    Mar 2013
    Upstate NY
    M3
    Woo lets see it eat!
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by PEI330Ci View Post
    Thank you for that.
    As I do yours!
    Quote Originally Posted by E36 HateR View Post
    I’m hoping it’ll get towards 1200whp but we might be out of turbo. I’m just excited to run it again.
    Quote Originally Posted by Mklock View Post
    Exactly!
    1989 535i - sold
    Nov 2013
    VA
    E36
    Sub'd. Boost away!
    Jul 2005
    PEI, Canada
    2001 330i
    Kenton tried with his S54 to break 1000rwhp, but had a really hard time above 26 PSI. It seemed like the engine got to a point where it took more power to drive the turbo, than the airflow off the edge of the map was able to provide back into the engine. Backpressure went up pretty fast above 26 PSI manifold pressure.
    I know of another S54 engine running a 6870 that is on it's 3rd turbo "trying" to make over 1000rwhp. I'm speculating that the failures were related to over-spinning the turbo, but I don't know for certain. (Nor does the owner)
    The only thing I can think of to help the situation would be to run an even bigger turbine housing....or maybe look at the new G42 Turbo from Garrett.
    Jul 2005
    PEI, Canada
    2001 330i
    I am of course assuming you are using the 6870 which the "cover" is listed on your hardware. If you are using a different turbo...I'm clogging up your thread!
    Mar 2012
    Renton, Wa
    98 m3
    Shoot I missed your replies!
    Yes, I’m using a 6870 hp-cover with 1.15ar t4 divided exhaust. I haven’t seen anyone push this housing and a proper manifold. Lots of 0.8x opens and a few 1.0 divided. Both similar in volume really.
    It has a nice 4” inlet, proper filter, good manifold. It’ll definitely crack 1000whp. It did 996whp at 5500 last time.
    I was looking at the g42 for similar reasons, but this is it for me. 6870 is more than enough turbo.
    —- onto a few updates. Sorry this is pretty sparse but we are so limited on time right now.
    So we finally got the proper nuts from arp on Thursday. Assembled the motor that night. Takes a while when you’re fully disassembling everything and cleaning it.
    125ftlbs on the head studs!
    10mm vs 1/2”
    Yesterday we finished the assembly, made up some new feed and drain lines, attached the trans (boy is the gs6 a monster), and installed it!
    Ran into a few issues, we grabbed a new Bosch 140, and it was the rear nut Type, instead of being threaded, and I cut up two bolts and welded them together, quickly. 30 minutes later the head shot off and across the shop! Ground and rewelded it with more penetration and did the same thing!!! Wild.
    Going to have to grab a few bolts and a plug for the head today.
    Going to work up a new m50 manifold, clean up some of the vacuum routing. The car has been revised so many times they need to be cleaned up.
    Got a new tstat, housing and hoses. This is really the most cleaned up the car has been!
    I did get the custom Ac lines back.You guys won’t believe how expensive they were.... but it’s done and we can finally remove those awful oem lines.
    And finally I’m updating my boost reference lines, they were 1/8” hardlines and I really feel it was hurting my low boost threshold. I could regulate down to 21/22psi. I was running two gates off a single 1/8” line. Going with some new 1/4” aluminum tube.
    1989 535i - sold
    May 2003
    quebec
    |99 Turbo M3 | 2K7 335|
    wow.. big project !! wish I had the guts to build something like that !
    _____________________________
    Jul 2005
    PEI, Canada
    2001 330i
    This might sound like an odd question, but how are you clearanc'ing the head gasket for the larger head studs.
    When I went from 10mm to 11mm studs, I had a really hard time with fitting the head gasket over the studs...a 12.7mm stud is going to need a big hole.
    Secondly, are you completely removing the alignment dowels on the head?
    Mar 2012
    Renton, Wa
    98 m3
    I cut a set of custom dowels.
    I used a sharp drillbit. It didn’t go great. Got the job done but I had to do a ton of post work.
    1989 535i - sold
    Oct 2005
    Northern California
    95 M3, 15 Golf TDI wagon
    I'm glad you're keeping the forums alive. Better than Facebook groups in my opinion.
    So for 1/2 head studs you also have to drill the head stud holes bigger right? Do you have to machine custom washers as well?
    Keep up the good work!
    -WTB: OEM Class 2 LTW GT wing with risers- Mazak
    Mar 2012
    Renton, Wa
    98 m3
    Quote Originally Posted by 3literheater View Post
    The 1/2” arp washers fit. Barely.
    There are a few more things we have to machine.
    The head stud holes all need to be clearanced for the stud. There are a couple stud holes that need extra clearance for oil passage to the cams. And finally the two dowels need to be cut.
    I did all of this manually myself. Quite stressful.
    1989 535i - sold
    Jul 2005
    PEI, Canada
    2001 330i
    So it's a challenge then!
    One idea I had was to lay the gasket onto the top of a piece of plywood, and then clamp it down with my torque plate. The bolt holes would be a good drill bit guide....
    A house
    '86 325e, '14 VW EPA
    When I still ran an MLS and before I discovered that Cometic will make you any bolt hole size up to 14mm, this was the method recommended to me by machine shops:
    https://www.youtube.com/watch?v=le9Y7BJ0cnc
    But for the cut ring, my friend machined me a punch of sorts. It just has the single layer of tin and strikes through pretty well. But I'll probably just use the clamp method if I have to get another cutring.
    Oct 2005
    Northern California
    Could you use this to cut the gasket?
    https://www.harborfreight.com/9-piec...set-95547.html
  1. BMWCCA-LA Chapter Last Auto-x of 2004 Postponed
    By jaramill in forum California sponsored by Avus Autosport
    Last Post: 11-15-2004, 04:39 PM
  2. Chris, Windy City Chapter, a truly nice guy
    By qwickm3 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-12-2001, 03:33 PM
  3. Question for Chris, Windy City Chapter
    By V Shah in forum 1992 - 1999 M3 (E36)
    Last Post: 03-06-2001, 10:01 PM
  4. For those who answered the BMW ACT questions I posted last month...
    By BMWguy206 in forum 1992 - 1999 M3 (E36)
    Last Post: 03-04-2001, 10:49 PM
