Results 1 to 4 of 4
Thread: Brake Wear Sensors Brand
    Houston, Texas
    1995 Dinan 740il
    Do anyone have an opinion/favorite brand?
    I replaced the pads, rotor and sensors (Bowa from FCP); the rear one fit but the front didn't so I reused the old one (which had not touched the rotor), the Check Brake Lining message came on and I bought a no-name and replaced the front but the "problem" was at the rear where the the plug wasn't completely plugged in. That all work for 2-3 weeks but Check Linings error started to flicker on and off and now is solidly on (and I'm due for my annual inspection at the EOM).
    These things a simple/cheap enough that I don't mind buying a pair and being done with it but $22 each for real BMW seems a bit high.
    Also, I checked ESC Tuning - They had better pricing but their regular shipping was $28, more than the 2 sensors!
    Thanks. Grady
    Jun 2005
    Florence KY
    1998 BMW 740iL
    I've been burned a few times buying the cheap brands for wear sensors. It kills me every time to buy genuine OEM but I just do it usually. I usually have good luck with Bowa but sometimes the shipping costs and availability are no good. If worse comes to worse you can always bypass the sensor and hardwire the sensor wires together to pass your inspection.
    Just keeping it reliable and looking decent.
    Houston, Texas
    1995 Dinan 740il
    I found out that sensor error may not be an inspection error... Fingers crossed. But with new everything new I want the light out!
    Nov 2016
    NY
    750IL/540iT/R53/E46Vert
    Yeah, the only good ones are OE. That being said, if you are on top of pad wear, just reuse the indicators - I only am on my third indicator on my wife’s r53 mini in 13 years, and 138k miles.
  1. E36 Brake Pad Wear Sensors - BRAND NEW and many available
    By dbbmwm3 in forum Brake Kits, Rotors & Pads
    Last Post: 05-15-2007, 09:56 AM
  2. Brake wear sensor gremlin...
    By C///M in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 10-12-2004, 10:16 AM
  3. Brake Wear Sensor replacement question
    By torquey in forum 1991 - 1999 (E36)
    Last Post: 08-30-2004, 01:45 PM
  4. brake wear sensor, can I jumper it?
    By Timberwolf in forum 1983 - 1991 (E30)
    Last Post: 04-27-2004, 12:41 AM
  5. Do I need to replace the brake wear sensor?
    By Jim//M3 in forum 1992 - 1999 M3 (E36)
    Last Post: 06-28-2001, 01:35 PM
