Results 1 to 10 of 10
Thread: crack around subframe bushing cylinder
    Jan 2019
    houston
    2017 F150, 97 M3
    Yesterday I tried using the maddox wheel bearing removal tool to pull out the subframe bushings. The tool was pulling the bushing out no problem, using my milwaukee fuel 1/2" impact to turn the tool. However about a 1/5 of the way in I noticed a slight bend starting where the subframe connected to the bushing cylinder. It's hard for me to tell but I think it slightly cracked it. I also noticed the factory welding is not entirely around the cylinder. Is this worth having fully welded in?
    If this looks like a crack what is the best way to have a welder fix this?
    What screws into that threaded hole? I'm wondering if some sort of reinforcement plate is put down, how much room around that hole is required to remain? subframe bushing crack 1.jpgsubframe bend 2.jpgsubframe bushing question.jpg
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    That looks more like damage in the finish (paint) than anything. Mine bent significantly more than yours did and never cracked. Never became a problem either. I would leave it, but if you're really worried you can have it welded and finish the weld around the cylinder, although I think it's overkill.
    Nov 2013
    VA
    E36
    Looks fine to me.
    Aug 2013
    1999 BMW M3 Coupe
    Yeah since you have it out you can have someone spend 5 minutes putting a weld on it if you're worried. Would be a good time to also weld in the reinforcement plates on the swaybar tabs if you haven't. I agree with others though that it doesn't look like a big deal and is probably fine.
    Jul 2011
    Austin, TX
    S54 E36 M3, E32 740il
    Quote Originally Posted by TostitoBandito View Post
    Backing up the swaybar reinforcement tabs comment - this is the easy way / time to do it. They're cheap enough there's almost no way to justify NOT doing it while the subframe is out. The AKG ones are only $20 - hard to ignore for that price.
    Nov 2010
    Whidbey Island, WA
    1998 Techno M3 Coupe
    Why impact wrench? You have almost no control or feel of what is happening when you impact something. There is a place for impact wrenches but using a bar and turning slowly would seem a better choice here.
    Nov 2013
    VA
    E36
    Good call on sway bar reinforcements. Also go ahead and do rtab reinforcements if someone can swing by the whip.
    Jan 2019
    houston
    2017 F150, 97 M3
    Well Saturday I had a welder I found on craigslist weld in my rtab pocket reinforcements and the sway bar reinforcements, both which I got from AKG and everything fit pretty good. Had to make a few minor trims on the akg rtab piece to let it sit 100% flush against the floor or whatever you want to call it. I was pretty happy with how that went and he only charged me $210 for those. I ended up paying $120 to have him come back and weld this stuff today. I have this car torn apart and I don't want to have to do anything again so I figured why cheap out now. Ignore the camo looking primer, everything will be black again when finished. subframe bushing cylinders welded.jpgsway bar reinforcement 1.jpgsway bar reinforcement 2.jpgsubframe bushing cylinders welded.jpgsway bar reinforcement 1.jpgsway bar reinforcement 2.jpg
    Jan 2019
    houston
    2017 F150, 97 M3
    here's a few shots of the welded rtab pocket. No issues with any of the factory welds around where the bolts go; purely preventative work that was done.
    Feb 2009
    Long Island, NY
    97 M3 & 13 Rav4
    Make sure you paint with self etching primer and use seam sealer
  1. Cracked subframe-Should I go with OEM subframe bushings?
    By alpinem3/// in forum Forced Induction
    Last Post: 10-09-2018, 04:45 PM
  2. Cracks Around Subframe Mounts - Hack!
    By MYBOXBIMMER in forum 1982 - 1988 (E28)
    Last Post: 12-05-2016, 08:43 PM
  3. Replies: 7
    Last Post: 04-12-2012, 01:11 PM
  4. Subframe Bushings = no subframe cracks??
    By DubSport in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 06-20-2007, 12:29 PM
  5. cracked front sway bushing
    By psk145 in forum 1991 - 1999 (E36)
    Last Post: 06-28-2002, 01:38 PM
