Results 1 to 11 of 11
Thread: Rear Muffler Stud Part Number on M5?
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Hey gang,
    I'm trying to fix some little things on my M5. Last time I removed the exhaust, a full 10 of the 12 exhaust hanger bracket studs came out of the body completely. The studs stick down from the body and provide a centering pin for the rear muffler hangers to mount to. The nuts (07119906089) have basically rust-welded themselves onto the studs, and I can't seem to find them on RealOEM.
    Circled is the stud (there are 12 total, six for each muffler) I'm talking about:
    Nate J.
    (oOO\ (|||)º(|||) /OOo)
    (eŌō\ (||||)º(||||) / ōŌe)
    JimLev's Avatar
    Sundance Mesa, NM
    00 540/6, '16 Highlander
    Those mufflers look just like my Vibrant muffler.
    What's the thread size (M8) and pitch of the ones you took out? Can't you get some threaded rod and nuts to make your own?
    Jan 2016
    Ca
    2001 525it
    I looked on the parts film for the studs you would think they would be section 41, body structure, but did not find any thing
    Buena Park, Ca
    2002 BMW 540i/6, 2003 BM
    You may have to take some measurements yourself and go to McFadden Dales and get some studs
    Sent from my LG-H932 using Tapatalk
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Yeah, M8. Dunno the pitch. The factory part is very nice, as it has an unthreaded portion that acts nicely as alignment dowels when the exhaust is reinstalled.
    Quote Originally Posted by jclausen View Post
    Thanks, I wasn’t able to find anything either.
    Quote Originally Posted by setho View Post
    Alternatively, if there is a way to chemically remove the rust-welded copper (?) nut from the stud... I may give “Metal Rescue” a go.
    Nate J.
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    Found a part number from the non-M E39 muffler mounting studs, which I believe are identical. BMW 18211433080. Except these studs are $30. Each. On the low end.
    Yikes.
    I'm going to try and go to a local junkyard and yank these studs to see if it fits. If it does, I'll grab as many as I can from local salvage yards. E39s are common in pick-your-parts locally, which is nice.
    ECS Tuning almost always has the best images for parts on their site, so if you want to see this stud:
    https://www.ecstuning.com/b-genuine-...h/18211433080/
    Nate J.
    JimLev's Avatar
    Sundance Mesa, NM
    Yikes, $30 for a $1 piece of threaded rod with the end turned down.
    Got a bench grinder? You could make one in 5 min.
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    I know, haha. I don't, but I have easy access to one at work. As opposed to the junkyard approach, I'm going to see if I can figure out the thread pitch, buy some 50mm M8 studs of that pitch, and grind them.
    Nate J.
    JimLev's Avatar
    Sundance Mesa, NM
    Most likely it's M8 X 1.25.
    That's what all the M8's I have are.
    You could measure the distance between two threads however if you measure the distance between 10 threads then divide by 10, that's your pitch. Easier this way.
    Sep 2014
    North OC, CA
    01 M5 TiAg/M1SW
    I have a super cheap set of Horror Freight thread taps/die; the most useful tool in there is a set of feeler gauge-like things that have different pitches.
    Nate J.
    geargrinder's Avatar
    Mar 2010
    AndoverRockport MA & Intl
    E46M3Cic E39.540iT E84X1
    $30 that's just lovely. So is the future of all our parts sadly, now that the automakers have the "gouge the parts prices once the cars are in the hands of people who will never ever buy new ones" strategy.
    One advantage of the factory one is that it does look plated for corrosion resistance. Unless you make one out of stainless then grinding (or better yet, turning...) a stud down is gonna take the plating off. Mebbe since you live in Cali the junkyard ones will be clean....
    On other hand, while I can see being extra long to help the fit-up being handy, I'm not so sure you really need the taper bit on the end? If you google around for stainless M8 studs, you can find all kinds of stuff, just most of them are square ended. I might just go that route and not sweat the taper-tip thing.
    Oh and ECS image insert:
    2003 M3CicM6 TiAg
    Former:
    1985 MB Euro graymarket 300SL
  1. Rear bumper clip part number?
    By connorb850 in forum 1991 - 1999 (E36)
    Last Post: 10-07-2007, 06:54 PM
  2. rear window shade part number
    By gameeffect in forum 1995 - 2001 (E38)
    Last Post: 06-03-2007, 09:20 AM
  3. E36 Rear window rubber part number help
    By ACS S3 in forum 1991 - 1999 (E36)
    Last Post: 03-13-2006, 01:10 PM
  4. Rear Shock Mount part number
    By paul e in forum 1996 - 2002 Z3 (E36/7, E36/8)
    Last Post: 03-26-2004, 04:38 PM
  5. Rear Trailing arm part numbers?
    By BMWM3some in forum 1992 - 1999 M3 (E36)
    Last Post: 11-10-2001, 02:28 PM
