Results 1 to 6 of 6
Thread: Time for a slush change
    moroza's Avatar
    moroza is offline MORΩN ΛABIA BMW CCA Member
    BFE
    E34T
    My 525iT's slushbox was allegedly rebuilt "recently" as of a couple of years ago. I hate automatics, but this one works fine and I don't have the resources for even a stock 5-speed manual swap, let alone the 6-speed it deserves, so it's best to take care of it in the meantime. Were it original, I'd go "f--k not with", but I figure it hasn't been too long since its last change, so I bought two gaskets and a filter... now what about ATF? Any recommendations? All I've ever needed ATF for was steering fluid, and just went with whatever was cheap, but this is a fussier machine.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Is that the GM A4S270/310R ?
    Black label on the pan or green label?
    NW suburban Chicago
    hiss by my window
    GM trans? Dexron
    Don't forget to drop and clean the front O/D section oil pan. The gasket for it needs to be ordered separately, doesn't come with "kits"
    Albuquerque, NM
    way too many
    ditto, Dexron. Spring for the extra bucks and get full synthetic i.e. Amsoil, Mobil 1, Redline, etc.
    Application chart:
    http://www.nmia.com/~dgnrg/SD92-113.pdf
    ​"The US Olympics bobsled team has renamed their sled 'Biden' because nothing has taken America downhill faster"
    TheStigg (aka "gale")
    92 735i 5-spd, turbo pending
    89 535i 5-spd (may she rest in pieces)
    94 325ic 5-spd
    87 325is
    moroza's Avatar
    BFE
    E34T
    I hadn't actually looked at the label, but assumed it's Dexron. I was asking for a product recommendation. Yes, I separately ordered the front gasket.
    Is the likelihood of transmission seal leaks from switching to synthetic comparable to that with engines? I'd like to give it high-quality oil but damned if I have to replace the input seal shortly after.
    Albuquerque, NM
    way too many
    Well, might just have to roll the dice on that one. I believe all current flavors of Dexron which are backwards compatible with the Dexron III, which was the original spec for your trans, will be at least a synthetic blend if not full synthetic. Depending on brand, some Dexron III's back in the day could be synthetic/synthetic blend. If the input seal is an occasional drip, then so be it. On the down side, a pronounced leaky front seal could be a bigger problem as in the 535i/735i ZF 4hp22, which usually leaks because the torque converter journal bearing walks forward and pushes the seal out. Let's hope you don't have to deal with such a scenario in the dead of winter. On the upside, it's an easy fix once the trans is out.
    94 325ic 5-spd
    87 325is
  1. Is It the time for me to change my headlights ???
    By Ken21 in forum 1996 - 2003 (E39)
    Last Post: 01-17-2006, 05:40 PM
  2. e46: possible timing chain/tensioner/vanos change time?
    By ///Mik in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 08-03-2005, 01:10 PM
  3. The time has come to change the starter today!
    By Joelude in forum 1992 - 1999 M3 (E36)
    Last Post: 07-23-2005, 11:54 PM
  4. Time for a wire change?
    By BruceY in forum General BMW Mechanical Help sponsored by RM European Auto Parts
    Last Post: 03-09-2003, 07:19 AM
  5. Replies: 0
    Last Post: 09-06-2002, 05:05 PM
