Results 1 to 25 of 62
Thread: 98 e38 obd2 unable to connect
    Jan 2019
    Bend, Oregon
    1998 BMW E38 740i
    Just bought the car, previous owner didn't keep good records and doesn't know much about it. Battery wouldn't hold a charge and replaced it with a new one. Check engine light is on, fuses seem to be fine. 20pin connector under the hood is connected and looks to be in good condition. Tried multiple OBD2 scanners, all come back with an unable to connect/read error.
    OBD2 port is getting 12v on pin 16, however I'm unsure what the other pins should be. Any ideas on what's going on? I've seen mixed information online, some people say that obd2 is only for smog testing which doesn't sound right to me. If someone could set record straight I would greatly appreciate it. Won't be able to test from the 20pin until Tuesday/Wednesday.
    Edit: Main issue is the car is in limp mode(trans failsafe prog.), hoping the codes will give me more info on why.
    Jan 2005
    Japan
    11/88 E32 750iL+98 E36M3
    Moved to E38 forum
    Mar 2013
    Sonora, ca
    2001 740il
    Obd plug is for air bags, etc. not for dme. look into obd threads there is a mod you can do to the 20 pin to make obd plug work.
    Jan 2019
    Bend, Oregon
    1998 BMW E38 740i
    obd2 scanner doesn't connect at all, no functionality what so ever. Is that normal for this car? after 96 obd2 was made standard, I would expect some functionality from this port even if limited.
    Feb 2010
    Hampshire UK
    99 840ci Sport Indv
    The under-hood 20-pin diagnostic port allows connection to all modules on the E38. Later models had an additional OBDII port in the cabin - and that was restricted to diagnosing the engine and gearbox. The additional OBDII port was added to allow SMOG tests to be made as was mandated by CARB.
    https://www.meeknet.co.uk/e38/obd2-bmw20.pdf
    My BMW Repair YouTube Channel
    Mar 2013
    Sonora, ca
    2001 740il
    Tiimm’s right. Like I said there is a mod that can be done to the 20 pin that will allow full access through obd port
    Jan 2019
    Bend, Oregon
    1998 BMW E38 740i
    https://www.bimmerforums.com/forum/s...endly-OBD2-mod
    I assume this is the one you guys are talking about? I'll give it a try and see what happens.
    Jan 2019
    Bend, Oregon
    1998 BMW E38 740i
    Hopefully this works and doesn't short something
    Jan 2019
    Bend, Oregon
    1998 BMW E38 740i
    No luck, still can't read from obd2. All scanners just load for a while and say they can't connect. Also noticed the check engine light isn't on when the car is running, only during bulb check. There should definitely be a check engine light on.
    Mar 2013
    Sonora, ca
    2001 740il
    Bummer time to pull the dme and check for connection problems. And check fuses too
    Jan 2019
    Bend, Oregon
    1998 BMW E38 740i
    Fuses are fine, any way of testing dme without special tools?
    Mar 2013
    Sonora, ca
    2001 740il
    Not sure on that, but should check to see if you have water damage to the dme connections.
    Rutland, Vermont
    E30 E38 E46 E85 F150 GTI
    Use an older OBD scanner. I have an old one I use for the E36 and E38 and I connect using the port inside the car. Tried using a newer one from Amazon on the old cars and just got a communication error. Vice versa when I try to scan the X3 - old scanner does not work, new scanner does.
    But for your problem you are better off using INPA and connecting to the round pin under the hood. The Mod above will allow you to use INPA when connected to the port inside the car.
    2000 740i Sport | 2004 330xi | 1988 325i Vert | 2003 Z4 2.5 | 1995 Ford F150 | 2018 GTI
    Jan 2019
    Bend, Oregon
    1998 BMW E38 740i
    There seems to be a lot of options out there for Diagnostic systems outside of the standard obd2, most of which goes over my head.
    I'm currently looking at something like this, comes with a ADS/ODB 20-pin adapter. My current plan is to find a windows xp laptop, get a k+dcan kit off Ebay and go from there. Does this seem right, are there better alternatives?
    Mar 2013
    Sonora, ca
    2001 740il
    Quote Originally Posted by Toomuchsugar View Post
    Bimmergeeks
    Mar 2013
    Sonora, ca
    2001 740il
    I purchased off eBay, don’t waist our time. I’m stuck with a system that barely works and is missing all the key codes. Had to reconfigure most of it and still have problems.
    Jan 2019
    Bend, Oregon
    1998 BMW E38 740i
    Sorry?
    Mar 2013
    Sonora, ca
    2001 740il
    No tears, lol. I will admit that the problems I’ve had do make me more knowledgeable. But bimmergeeks is proven and widely used. Plus you can use software on any computer no need to buy another lap top
    Jan 2019
    Bend, Oregon
    1998 BMW E38 740i
    I don't have a laptop, don't plan on lugging my desktop down to the garage. Figured I would go for something that wouldn't have driver compatibility issues. I'm confused because you're said "don’t waist our time." did you mean don't waste your time, as in mine, by buying from ebay rather than bimmergeeks?
    Mar 2013
    Sonora, ca
    2001 740il
    Sorry eBay, were my rant started from. If you don’t have a laptop you could also consider rheingold too. Bimmergeeks has the best d/k can cable and free software
    Rutland, Vermont
    Quote Originally Posted by Sundaycruzer View Post
    Pretty sure rheingold is only for a laptop? Most of what is on Bimmergeeks that's not for laptops is for newer cars or the cables and software links to install on laptops that will work on the older cars.
    For what it's worth, I think your best bet is to get a cheap laptop running windows 7 (no need to downgrade to XP) and get the software download from bimmergeeks. Not hard to get it going. You can buy your cable from them, or this ebay link I got from a member on here who has helped me out a lot with INPA. I agree you never know what you will get on ebay but this came from a trusted source.
    https://www.ebay.com/itm/123208665299?ul_noapp=true
    Mar 2013
    Sonora, ca
    2001 740il
    Quote Originally Posted by clarkitect View Post
    Rheingold is basically ista/istp. And will do e/f generations and rheingold can sell it already downloaded on their laptop ready to run. Bimmergeeks is fundamentally just software, will have to still download sp-daten and etc before it will function.
    Rutland, Vermont
    You can also buy a whole laptop set up with software from member Trasportador. I think he charges $200 for the whole deal. Probably still need to buy a cable but pretty sure he would make a recommendation.
    Jan 2019
    Bend, Oregon
    1998 BMW E38 740i
    So bimmergeeks doesn't have a abs/obd 20 pin adapter, so that doesn't work for me.
    Rutland, Vermont
  1. Replies: 1
    Last Post: 09-24-2013, 03:26 PM
  2. E38 brand new clear corners for facelift (98+) e38
    By eta1987 in forum Exterior Lighting & Body Parts
    Last Post: 07-02-2012, 09:07 AM
  3. E38 98 e38 transmission needed - A5S440Z
    By IcePlanter in forum BMW Parts Wanted
    Last Post: 12-13-2011, 02:11 AM
  4. E38 Anybody need a aux fan for a 95-98 e38
    By sikride250 in forum Exterior Lighting & Body Parts
    Last Post: 07-14-2010, 03:54 PM
  5. FS: Stock 98 M3 OBD2 ECU
    By M3Jokster in forum BMW Parts For Sale
    Last Post: 12-22-2003, 02:22 AM
